ftp connecting to my bsd flash drive and not my files??
cant get freenas to show my files in ftp
username and password is ok
ddns is ok
nat is all set up ok
in reenas the ftp server is turned on and i think is set up ok
ive accepted i will always be a freenas noob
System Information
Hostname nibbler.local
FreeNAS Build FreeNAS-8.0.2-RELEASE-i386 (8288)
Platform Intel(R) Atom(TM) CPU D525 @ 1.80GHz
Memory 3049MB
System Time Wed Nov 21 03:38:17 2012
Uptime 3:38AM up 9:24, 0 users
Load Average 0.15, 0.10, 0.08
OS Version FreeBSD 8.2-RELEASE-p3
ben
FreeNAS GUI Developer
Maybe uncheck "allow root login" and use a luser (local user) login instead.
i still have no idea why the ftp would/could point to my freebsd drive
thanks for the help ben, i did try your sugestion but it didnt work
i updated to freenas 8.0.3 and the problem was solved
ben
Glad your problem is solved. Must have been an old bug that got fixed in more recent versions. Presumably you mean 8.3.0 not 8.0.3? 8.0.3 is pretty outdated, 8.3.0 is the most up to date version.
