Fresh Plex install (11.2-U7). Can not get past the "No Soup for You" Error.
I have performed the following steps and am confronted by the plexmediaserver "No Soup For You" error. Please help.
1) Using the GUI (FreeNAS-11.2-U7) I remove the existing plex Plugin installation and verify that "jails" in iocage is empty.
Here is my Storage Pool with no jails:
2) I go to the Plugins menu, select Available, filter for "plex", left-click the three stacked dots next to the Plex Media Server listing and select "Install."
3) I leave the default Plugin Name of "plexmediaserver" and DHCP is selected by default. I click "Save." (wait for install to complete)
4) I go to the Jails menu, left click the three dots next to the new plex jail and select "Shell". I use the resulting shell to access the plex jail and create destination directories:
5) I stop the plex Plugin. Then, I add the two mount points to the plex Jail, connecting the /mnt/movies and /mnt/music jailed directories to their respective /mnt/tank/media datasets.
6) I restart the plex Plugin and wait 5 minutes. I left click on the three dots next to the plex Plugin and select "Management:"
I sign in to my Plex account, as prompted. and I immediately see the "No Soup For You" error message.
I have verified in the plex jail, that the mount is successful and the permissions match in both locations.
I have been trying this every which way I can find on line and none of the suggestions have helped.
Thank you, in advance, for any assistance.
-Darryl
Seems there was an issue for me getting this a ways back, what I always did was logout within the plex web interface and immediately log back in... Seems there was a token mismatch or something. Give that a try.
Hunter844
I'm having the same trouble and I've tried installing plex media server every which way i can following several tutorials. It won't allow it. I can use a freenas vm and I can add the server at that point but not through a plugin/jail. I thought maybe it was a iocage issue but I have yet to figure out how to pin point the issue.
Randall_64
Hi everybody,
Install FreeNAS 11.3 RC2 (or newer) Plex plugin with static IP address. These notes are not scientifically proven but reproducible for myself to create a PMS.
Create user ‘plex’ with ID 972 at Primary Group ‘wheel’. The Plex plugin allways uses this user in it’s jail with corresponding userid. You need this user at the next step.
At the Dataset where the media is located, choose edit ACL. Under File Information choose User -> plex and Group -> wheel. Check Apply permissions recursively. Confirm, Continue, Save.
Install Plex plugin with DHCP settings. Just enter the name of the jail and there you go. Just accept DHCP because static IP address is not possible initially to get it right. You can change the IP config later to static IP. The Plex plugin with it’s jail will be started after install automatically.
Stop the Plex jail
Edit the Plex jail
Basic properties:
· Uncheck DHCP Autoconfigure IPv4
· Leave VNet checked
· Leave Berkely checked
IP4 interface: leave ----------------
IP4 address: (free IP address for your Plex jail)
IP4 netmask: (your netmask)
Default router: (your gateway)
· Leave Autostart checked
Jail properties:
· Check Allow raw sockets
Network properties:
· Leave all unchanged
Custom properties:
Save settings
Start the jail to check if it’s working
If yes:
Stop the jail again
Create mountpoints
Start the jail
Now you’ve created the dependencies for the Plex web gui. At this gui you can create your media entrances without errors ‘no soup for you’ or ‘no items available.
Regards, R.
ZiggyGT
I have been struggling to get my system back up again. I have had Plex working in a Jail under 11.2 for some time. One day the server could not be seen by plex, I added the IP of the name server and everything was fine for awhile. Then again the server could not be found. The FREENAS files storage is seen by all my Win 10 machines, but the plex web page cannot see the server. I have deleted the Jail and tried to reinstall PLEX but no joy. I brought up a nearly identical systems and installed PLEX. that seems to be OK. There is a gremlin here. Here is a dump of the ifconfig command output. I have a 1Gb network card and 6x10Gb Melanox cards. I temporarily took out the bridge creation script to simplify things until it is working again. I rebooted without the script to make this output. This was working well for a long time. Please take a look. I really need some help. I do not understand wiy bridge0 is showing up in the ifconfig as disabled the startup script.
root@freenas[~]# ifconfig
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether 78:ac:c0:bc:d5:2f
hwaddr 78:ac:c0:bc:d5:2f
inet 192.168.0.82 netmask 0xffffff00 broadcast 192.168.0.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
mlxen0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=ed07bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:02:c9:0e:38:a2
hwaddr 00:02:c9:0e:38:a2
status: no carrier
mlxen1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:02:c9:0e:38:a3
hwaddr 00:02:c9:0e:38:a3
media: Ethernet autoselect (autoselect <full-duplex,rxpause,txpause>)
status: active
mlxen2: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:02:c9:0e:38:9a
hwaddr 00:02:c9:0e:38:9a
status: no carrier
mlxen3: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:02:c9:0e:38:9b
hwaddr 00:02:c9:0e:38:9b
status: active
mlxen4: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:02:c9:07:99:cc
hwaddr 00:02:c9:07:99:cc
status: active
mlxen5: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:02:c9:07:99:cd
hwaddr 00:02:c9:07:99:cd
status: active
ether 02:18:ca:89:31:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plex-plexpass as nic: epair0b
options=8<VLAN_MTU>
ether 02:ff:60:30:63:77
hwaddr 02:28:10:00:0a:0a
status: active
groups: epair
Randall_64
status: active
groups: lo
status: no carrier
status: active
status: no carrier
status: active
status: active
status: active
groups: bridge
options=8<VLAN_MTU>
status: active
groups: epair
Hi ZiggyGT,
Though I don't have the skills to analyse the ifconfig, it could be a networking issue. I've read some other threads in the past. The subnet of the jail must be the same as the subnet of the Freenas server.
