Andrew Ostrom
- Jul 28, 2017
I installed the 12.0-U2 update to my system (was running 12.0-U1) a few days ago. Up until then my system was running with no issues. Since the U2 update I get an alert several times a day stating that the system has rebooted unexpectedly. I am not a Unix/Linux guru by any stretch of the imagination - my expertise was in the now obsolete VAX/VMS and RSTS/E operating systems.
My configuration is:
Looking at the files info.* in /data/crash, they are all similar to this:
I'm not sure exactly what this means, but the SMART status for da23 is good - I have started a "long" test on da23, which will take a few hours.
I think I am posting the right files here, but please tell me if I am missing anything.
Thanks for the help.
Supermicro SuperChassis 846E1-R1200B Dual Xeon, 24 x HDD Storage Server
Supermicro Motherboard X9DRi-F
Dual Intel Xeon E5-2690 v2 3Ghz
128GB Ram (16x 8GB PC3-12800R)
BPN-SAS2-846EL1 Backplane
2 LSI SAS9207-8i
2 120GB Kingston SSD Plus drives for system
Dual PWS-1K21P-1R 1200W 80 Gold Plus power supplies
Vdev1 (RAID-Z2) - 8 x 3TB Seagate SAS ES.3 ST3000NM0023
Vdev2 (RAID-Z2) - 8 x 4TB Seagate SAS ES.3 ST4000NM0023
Vdev3 (RAID-Z2) - 8 x 4TB Seagate SAS ES.3 ST4000NM0023
Chelsio 10Gbe (10Gbase-SR using fiber to Aruba switch)
Dump header from device: /dev/da23p1
Architecture: amd64
Architecture Version: 4
Dump Length: 1607168
Blocksize: 512
Compression: none
Dumptime: Thu Feb 18 09:24:00 2021
Hostname: freenas.ostrom.org
Magic: FreeBSD Text Dump
Version String: FreeBSD 12.2-RELEASE-p3 7851f4a452d(HEAD) TRUENAS
Panic String: trying to coalesce 8 packets in to one WR
Dump Parity: 2839218024
Bounds: 0
Dump Status: good
