Frequent reboots since 12.0-U2 update (cxgb driver panic)
Andrew Ostrom
I installed the 12.0-U2 update to my system (was running 12.0-U1) a few days ago. Up until then my system was running with no issues. Since the U2 update I get an alert several times a day stating that the system has rebooted unexpectedly. I am not a Unix/Linux guru by any stretch of the imagination - my expertise was in the now obsolete VAX/VMS and RSTS/E operating systems.
My configuration is:
Supermicro SuperChassis 846E1-R1200B Dual Xeon, 24 x HDD Storage Server​
Supermicro Motherboard X9DRi-F​
Dual Intel Xeon E5-2690 v2 3Ghz​
128GB Ram (16x 8GB PC3-12800R)​
BPN-SAS2-846EL1 Backplane​
2 LSI SAS9207-8i​
2 120GB Kingston SSD Plus drives for system​
Dual PWS-1K21P-1R 1200W 80 Gold Plus power supplies​
Vdev1 (RAID-Z2) - 8 x 3TB Seagate SAS ES.3 ST3000NM0023​
Vdev2 (RAID-Z2) - 8 x 4TB Seagate SAS ES.3 ST4000NM0023​
Vdev3 (RAID-Z2) - 8 x 4TB Seagate SAS ES.3 ST4000NM0023​
Chelsio 10Gbe (10Gbase-SR using fiber to Aruba switch)​
Looking at the files info.* in /data/crash, they are all similar to this:
Dump header from device: /dev/da23p1​
Architecture: amd64​
Architecture Version: 4​
Dump Length: 1607168​
Blocksize: 512​
Compression: none​
Dumptime: Thu Feb 18 09:24:00 2021​
Hostname: freenas.ostrom.org​
Magic: FreeBSD Text Dump​
Version String: FreeBSD 12.2-RELEASE-p3 7851f4a452d(HEAD) TRUENAS​
Panic String: trying to coalesce 8 packets in to one WR​
Dump Parity: 2839218024​
Bounds: 0​
Dump Status: good​
I'm not sure exactly what this means, but the SMART status for da23 is good - I have started a "long" test on da23, which will take a few hours.
I think I am posting the right files here, but please tell me if I am missing anything.
Thanks for the help.
  • textdump.tar.0.gz
  • textdump.tar.1.gz
  • textdump.tar.2.gz
  • textdump.tar.3.gz
  • textdump.tar.4.gz
  • textdump.tar.last.gz
  • info files.zip
  • messages.zip
Samuel Tai
This isn't a problem with da23. The crash is in the cxgb driver trying to combine packets. Try disabling all offload options for this NIC.
Samuel Tai
Samuel Tai
Andrew Ostrom
OK, I will do that. Thanks for the help.
Update - I am now running 12.0-U1.1, and will file a bug report in Jira.
Update 2 - Bug filed - https://jira.ixsystems.com/projects/NAS/issues/NAS-109486?filter=allo*****sues
Update 3 - 2/22/2021 - the bug has been reported by at least one more user, and reproduced by a member of the dev team, so it's being worked. Thanks!
Update 4 - 2/22/2021 - A fix has been developed and is being tested.
Update 5 - 2/24/2021 - The fix has been committed to TrueNAS 12.0-U3 and also to FreeBSD main.
