mhankemann
- Oct 27, 2011
Dear Forum,
I use Freenas since two weeks.
In this two weeks the server freeezes two times!
Freenas is installed on a Intel Core 2 Duo with 2 GB Ram. (No VM!)
When it freezes i cant use the prompt on the screen (i tryed to reboot after the Shares are unavailable). There is no reaction when i type something on the keyboard. Its just freesed.
The terminal in the webGUI tells me:
Oct 26 11:44:45 NAS-SERVER-01 kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Oct 26 11:44:45 NAS-SERVER-01 kernel: WARNING: /data was not properly dismounted
Oct 26 11:44:45 NAS-SERVER-01 kernel: ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
Oct 26 11:44:45 NAS-SERVER-01 kernel: add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Oct 26 11:44:45 NAS-SERVER-01 kernel: ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
Oct 26 11:44:45 NAS-SERVER-01 kernel: Consider tuning vm.kmem_size and vm.kmem_size_max
Oct 26 11:44:45 NAS-SERVER-01 kernel: in /boot/loader.conf.
Oct 26 11:44:45 NAS-SERVER-01 kernel: ZFS filesystem version 4
Oct 26 11:44:45 NAS-SERVER-01 kernel: ZFS storage pool version 15
Oct 26 11:44:45 NAS-SERVER-01 root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Oct 26 11:44:48 NAS-SERVER-01 ntpd[1908]: ntpd 4.2.4p5-a (1)
Oct 26 11:44:49 NAS-SERVER-01 avahi-daemon[2134]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Do I habe any problem?
Whats about "Consider tuning vm.kmem_size and vm.kmem_size_max"???
