FreeNAS via Wifi
Kaaall
I have some problem to set up FreeNAS about Wifi. On the place where FreeNAS stands is no Lan available, but I saw somewhere that you can configure FreeNAS about wifi. So how do I do this with a PCI wireless Linksys card?
Thanks,
Kaaall
jgreco
Resident Grinch
You would be *so* much better off finding a way to get wired connectivity if you can. It should be possible to make FreeNAS work with any networking technology supported by FreeBSD, but it isn't going to work out of the box. You'll have to put in a little time and effort configuring it through a shell script. I'll leave that for someone else to expand upon.
