Jeremy Stromsoe
- Dec 16, 2014
Problem: Need help with GUI RAIDZ setup
I've got a single stripe setup with the 2x3TB drives. I'd like to completely re-volume everything with a Raid Z1, which I thought would be simply a drop down choice in the volume manager. It is not in FreeNAS 9.3. I added a second set of 2x3TB to accomplish this, with now 4x3TB drives total.
Some background/detail:
I had setup my system exactly as described in signature except with 2x3TB drives striped across to start with.
Of course then I realized how bad of an idea that was given the amount of data stored and having one drive fail with no real recourse except replacing and copying my backup external drive.
To be "safe" I want to add an additional set of 2x3TB drives, especially after reading about the benefits of having a RAID Z1 configuration with 9TB usable and still being able to simply replace a bad drive and have it resilver. On top of that I have an external drive rsync backup.
The only options in the drop-downs in my volume manager is Stripe/Volume/Cache/Mirror or Log. After several hours of searching for a solution, all the FreeNAS documentation regarding RAIDZ talks about a drop-down option for various configurations of RAIDZ in the volume manager. I think this might be a case of the documentation has not caught up with the software release, because this options is nowhere to be seen when I attempt to add one of my new disks as a volume.
I also found in the "wizard" menu at the top of the web GUI that the initial setup allows you to choose RAIDZ, but all those options are greyed out, I'm assuming because I am past the initial setup phase of FreeNAS.
So my question is, can I leave all my FreeNAS settings/config the same but re-volume all 4 drives to RAID Z1, or must I begin from square 1, re-install FreeNAS to my flash drive so that the wizard will let me choose my RAID config, and then re-apply all my permissions, shares ect...? What's the easiest way to do this? Keep in mind I have backup copies of my data; I do not care about loosing everything on the original drive set. Plan is to copy it over from the backup once I'm finished with the RAID Z1 setup.
Thanks for reading, sorry its long :), any help would be greatly appreciated (I might sleep better!!).
