Current Setup Running FreeNAS 0.7.1
CPU: Intel Pentium 4 2.0A Northwood 2.0GHz Socket 478 (circa 2002)
Mobo: ASUS CUSL2 (circa 2002)
RAM: 1.0GB
HDDs: 2x Seagate Barracuda 7200.10 ST3500630AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s
Hardware RAID: 3ware 8006-2LP PCI 64-bit SATA 2-port SATA RAID Controller
NIC: Intel PWLA8391GT PRO/1000 GT Desktop Adapter 10/ 100/ 1000Mbps PCI
RAID TYPE: 1
Share Type: SAMBA
Comments on old hardware: Zero problems to date. *Knocks on wood*
File Server Purpose: Home file server for 3-4 local machines, HDTV, etc.
Upgrade Goals:
1. Capacity Upgrade: 500GB to 2TB or more. (I currently use about 400GB of the 500GB available. This has been enough for me for 3 years.)
2. Speed Upgrade: Faster write times especially would be nice. (I do have a "gigabit network" with appropriate routers, switches, and cables.)
3. Increased reliability.
4. Keep in mind that the system is always on.
5. I would like to use shares as libraries on local Win7 machines.
6. The server does not really do much serving outside of the house. If does, it will do do only through SSH.
Upgrade Ideas:
-Instead of SAMBA, I would like to migrate to NFS shares to increase throughput.
-Instead of hardware RAID, I will probably use the SATA ports on a new motherboard and let FreeNAS do the rest.
-Instead of RAID, I have read a lot of good things about ZFS. I think I am comfortable setting up a a ZFS system within the confines of FreeNAS.
-I like FreeNAS. I plan to upgrade to 8 with this build. I am not really entertaining ideas of WHS, etc.
-Regarding ZFS, I still have not decided whether to do a simple mirror or Z1 or Z2. Obviously this decision also depends on the size and number of HDDs I can buy.
Budget:
$500-$600 USD
Preferred Vedors:
Newegg, Amazon (I prefer to build my own boxes.)
Hardware Option 1 (using newer older spare parts):
CPU: AMD Opteron 170 (supports ECC memory)
Mobo: ASUS A8N SLI Premium (supports ECC memory BUT max. 4GB only)
RAM: 4x 1GB ECC Unregistered DDR400 RAM would cost about 4x $50 or $200.
HDDs: Undecided?
Hardware Option 2 (new build)
CPU: AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 95W Quad-Core (ECC Support)
Mobo: ASUS M4A88T-M LE AM3 AMD 880G HDMI Micro ATX (ECC Support)
Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) ECC Unbuffered Server Memory
HDDs: Undecided? (This build would obviously leave less money in the budget for more drives unless I went with 1TB drives instead.)
Questions:
-How necessary (or recommended) is ECC memory for running ZFS?
-Are the SAMSUNG EcoGreen F4 HD204UI 2TB SATA 3.0Gb/s drives good enough for a ZFS build?
-Obviously I would buy a minimum of two such drives for a mirrored solution. Or a minimum of 3 or 4 for Z1 or Z2 solutions, respectively.
-For my simple home application (refer to Upgrade Goals above), what do you all recommend?
Mistakes:
-Hereforfore I have NOT employed a backup of my RAID 1 system. I know this is a mistake.
-An external 500GB drive enclosure will be used to backup critical elements of the FreeNAS system.
Thanks for reading.
RAM: 1.0GB
RAID TYPE: 1
Share Type: SAMBA
Upgrade Goals:
Upgrade Ideas:
Budget:
$500-$600 USD
Preferred Vedors:
HDDs: Undecided?
Questions:
Mistakes:
Thanks for reading.
