Freenas unreachable when installing into a virtualbox machine.
mikele83
Hi to all,
I've a problem while trying freenas into a virtualbox machine environment.
It doesnt get IP from DHCP but not only, if I set ip and netmask manually I'm not able to connect via browser to the web interface and pinging it doesn't works neither.
I've set the virtual nic card in Host-only mode bridged manually in windows network connection. (I have others virtual machines setted at same way and they are all reachable).
I've tryed to set the nic in bridge mode directly into virtualbox but neither it works.
All helps will be welcome. :)
mikele83
Hello people,
with x64 version of freenas the problem disappeared!
It runs in dchp and also manually. ;)
