I’ve recently purchased 2 shitty PC’s with the aim to max their drives out and put Freenas on it.
Aim is to use all my leftover 500 GB HDD’s which I currently use as cold storage in a Freenas setup. The RAM will be around 8GB of DDR3 RAM probably.
That means they get used once every 3 months, maybe even 6 months, for a few days and then get turned off again.
Thanks
- Is Freenas a good choice for this?
- Will the IP of Freenas stay the same after I’ve not used the setup for months?
- I plug in 6 HDD’s and USB stick with the OS. I’ve searched and if the USB stick dies it’s relatively easy to get the data from the pool back.
How can I make sure that if 1 of the 6 HDD’s dies, I can still rebuild my pool? Which ZFS or whatever should I choose?
Thanks
