FreeNAS Speeds??????
tmacka88
Hi guys, just want to know what kind of transfer speed you guys are getting using freenas and what components affect the speed e.g gigabit network car etc.
cheers
survive
Behold the Wumpus
Hi tmacka88,
I just did a quick "dd" test on my box & here's what I got:
filer# dd if=/dev/zero of=testfile bs=8192k count=1000
1000+0 records in
1000+0 records out
8388608000 bytes transferred in 14.092086 secs (595270856 bytes/sec)
According to Google that works out to about 567.694527 MB/sec
That's writing straight to the disks internal to the box, which is way more than enough performance to max out a gig-e connection. I can usually come pretty close to maxing out the connection over CIFS.
Personally I think just about any modern CPU should be sufficient for a single gig-e connection....take a look at some of the threads from folks running Intel Atoms or AMD Hudson (E-350) boards and they are evengetting great results. If you give your system enough RAM, use a quality (Intel) NIC's and connect everything through a good stand-alone gig-e switch (don't use the ports on your DSL router\cable modem) and you should be happy.
-Will
