Been running great for 2 or so years now, then 2 days ago my shares got really slow(under 1mbit read speed) and my Jails stopped responding.  Tried to get into the web UI and it was also not responding.  SSH works but is also very sluggish, /var/log/messages is full of:
After a reboot it works great again for a couple hours, then stops responding/gets sluggish again. The same time it stops responding those "samba4" messages start up again.
When searching I found someone recommended to "have selected zfs_space, zfsacl and streams_xattr modules" on all SMB shares, those are all already selected on my shares. Another thread said a Windows 10 update was to blame, however I've avoided accessing any of the SMB shares from my windows or Linux machines and it still started happening again. When the problem started I was on version 11.1U4 and attempted an update to U6, but everytime I tried to update these samba4 alerts would start up and it would stop responding. Finally last night I took a backup of the config and installed 11.1U6 on a new USB drive, reloaded my config and the problem still exists. Not sure what else to try/look for now.
System Specs:
HP Z420 Workstation
Xeon X5679
12GB ECC Ram
6x WD AV 2.0TB
Sep 3 13:08:48 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: timed out Sep 3 13:13:03 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: Failed connection handshake Sep 3 13:21:36 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: Failed connection handshake Sep 3 13:26:59 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: timed out Sep 3 13:30:52 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: timed out Sep 3 13:34:27 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: timed out Sep 3 13:36:57 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: Failed connection handshake Sep 3 13:39:45 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: timed out Sep 3 13:41:40 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: timed out Sep 3 13:44:52 homenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814d0c828>' failed: timed out
System Specs:
HP Z420 Workstation
Xeon X5679
12GB ECC Ram
6x WD AV 2.0TB
