pieces_of_decay
- Mar 27, 2019
I am trying to get Sanoid/Syncoid to work with FreeNAS. I seem to be running into trouble at every step.
I have a Proxmox server. I'm running Sanoid directly on the host OS to take/manage snapshots. I am trying to send these snapshots, using Syncoid, to my FreeNAS box, which I will be using for backup. The FreeNAS box is a HP Microserver Gen 8. 12 GB RAM. Installed 11.2 from scratch a few weeks ago.
I want to also run Sanoid on FreeNAS (to manage snapshots). So I made a jail, and installed everything.
ZFS in the Jail
The first big issue I had was figuring out how to let the jail have access to the ZFS pool. Simply adding a Mount Point from the host doesn't work. In the "Jail Properties" I had to:
After figuring out all that, I could see the zpool in the jail.
Sending Snapshots
NOW, I tried to use Syncoid (which is a fancy wrapper for zfs send/receive). I'm doing this on the Proxmox host, sending to the FreeNAS box. I wanted to copy everything from my primary storage pool (on Proxmox) to this dataset on FreeNAS. After playing with some options, I came up with this command:
And it worked! For a bit. A large amount of data was transferred, but eventually it started skipping snapshots with the error:
The actual command that was run (edited out irrelevant info like SSH port & key):
And cleaned up even more (removing the compression, the "/usr/bin"s, the buffer, pv):
Questions
Does anybody have any ideas as to what the problem is? Any insight is appreciated.
There seems to be a file name limit somewhere?? (On a device/file system made for storage?) I'm not using a particularly long filename, I just measured at 57 characters in the actual error.
I know I'm using a 3rd party tool, and that introduces variables. But I don't think the issues are caused by the tool.
I can provide additional info if I left something out. Thanks again.
ZFS in the Jail
- Check
allow_mount
in "Jail Properties" - Check
allow_mount_zfs
in "Jail Properties" - Set
enforce_statfs
to0
jail_zfs
in "Custom Properties" - Enter a new dataset I created into
jail_zfs_dataset
on the "Custom Properties" page - (I also set the
jail_zfs_mountpoint
, but nothing is getting mounted to where I set within the jail. The specified dataset gets mounted to/mnt/pool_name/dataset_name
Sending Snapshots
# /opt/sanoid/syncoid --recursive primary_array root@192.168.1.101:backup_array/primary_array_backup
cannot mount 'backup_pool/storage_pool_backup/dir1/dir2/dir3/dir4': File name too long
# /sbin/zfs send -i 'primary_array/dataset@auto-20170530.0500-1y' 'primary_array/dataset-auto-20170530.0500-1y-clone'@'auto-20180109.0500-1y' | /usr/bin/pv -s 4096 | /usr/bin/lzop | /usr/bin/mbuffer -q -s 128k -m 16M 2>/dev/null | /usr/bin/ssh root@192.168.1.101 ' /usr/bin/mbuffer -q -s 128k -m 16M 2>/dev/null | /usr/bin/lzop -dfc | /sbin/zfs receive -s -F '"'"'backup_array/primary_array_backup/dataset-auto-20170530.0500-1y-clone
# zfs send -i 'primary_array/dataset@auto-20170530.0500-1y' 'primary_array/dataset-auto-20170530.0500-1y-clone'@'auto-20180109.0500-1y' | ssh root@192.168.1.101 zfs receive -s -F 'backup_array/primary_array_backup/dataset-auto-20170530.0500-1y-clone'
Questions
