FreeNAS play with a RAID Controller? And ZFS Questions
Hi all,
I'm new here, so apologies if this isn't the right place, and I'm asking a dumb question! I'm very new to the FreeNAS world, but I have an old computer lying around and want to turn it into a FreeNAS box. Here are my hardware specs:
- MSI B250M Bazooka mobo
- 16 GB RAM
- Intel i307100 CPU @ 3.9GHz
- 4 x WD Red 4TB Hard drives
- 1 x SilverStone ECS01 LSI 9261-8i SAS/SATA Controller, 8 Ports Internal, PCIE 2.0 x8, RAID 0,1,5,6,10,50,60
My main questions are:
1. How well will FreeNAS play with the Raid Controller? Can this be used to set up a proper ZFS file system?
2. Is using the ZFS file system my best option for data redundancy?
Thanks for any help!
K
m0nkey_
Chris Moore
Sell it on eBay and buy a proper SAS HBA like this:
https://www.ebay.com/itm/Dell-H310-...D-High-Air-Flow/162834671120?epid=19006955695
Trying to use that RAID controller will only lead to destruction.
That is a gaming motherboard and it must be a really terrible one because they are up for auction on eBay starting around $30 and nobody is buying. It has a lot of features that are not suited to FreeNAS. I would suggest getting a server grade motherboard, if you want a server, something like this:
https://www.ebay.com/itm/Supermicro...DR4-SATA3-USB3-0-V-2GbE-MicroATX/322333083804
It will work with the existing CPU.
joeinaz
The SuperMicro board suggested Chris also allows for the use ECC memory which is recommended for FreeNAS deployments. Speaking of memory, I am not certain but the X11SSL-F may require ECC (server) memory vs NON-ECC (desktop) memory which is likely what you currently have.
