Jason Taylor
- Apr 15, 2018
Hello
Noobie here, I've done some reading up on raid and FreeNAS and still have so many questions.
I'm an IT network engineer so considered a geek but I've never really dug into building raid before. My plan was to rebuild my unused Windows 10 home built desktop into a FreeNAS, as its only being used for storage as my laptop is more powerful and convenient. I then back this up to an external HD from time to time which is kept in a safe. So converting my desktop to a raided NAS would give me realtime failed hard drive redundudcy, and I would still keep my backup to external HD going (or possibly 2 so I can keep one connected to the NAS). I've got about 1TB of data currently, so 2 TB of useable raid storage should be ample for the time being.
I currently have 2 x 1TB Western Digital hard drives, and a single 1 x 2TB WD drive. Could I stripe across the 2 x 1TB, and then mirror onto the single 2 x TB? I think this would be called a hybrid raid z10 (if I could utilise ZFS). If I can't do this then I will just go and get another matching 2 x 1 TB HD's. Would anyone recommend a better raid setup?
AMD Phenom processor - from reading this is generally a bad idea as it does not support ECC which means I can't utilise ZFS? I suppose that would mean my current 8GB of ram is also non ECC? I need to do some more digging into this. I think I will give it a go either way, but if it won't work or I receive a load of don't even bothers, then I would rather go out and buy a Netgear ReadyNAS instead of buying a new intel processor and motherboard and the supported RAM!
Thanks, looking forward to reading your responses!
