- May 17, 2014
I really like the design of the FreeNAS Mini. But for me, it's more about speed and ease of maintenance.
(Meaning I want to be able to login and move things around locally.)
So I don't need 4 x 3.5" disk slots. Since 2.5" disks are now at 1TB, I figure I could get by with 4 x 2.5" disks.
Preferably hot-swap. If done right, I should beable to saturate 1Gbps Ethernet link. Especially if
I use that Asrock C2750D4I system board that the FreeNAS Mini uses.
Does anyone have a chassis suggestion that supports at least 4 SATA 2.5" hot swap disks and a Mini ITX
system board? (With the card slot still available?)
If I can't find anything suitable, then I will likely just bite it, and buy the FreeNAS Mini.
