FreeNas logs out every 2mins
ynandana
Hi Team,
I'm using FreeNAS-11.1-U5, on cisco ucs c240m4 baldes. I have three such setups, first one seems to be working fine but the other two, for some reason keeps logging out for every 2 mins or less. Please help me resolve this issue.
Chris Moore
Can you upgrade to FreeNAS-11.1-U6 or is there some reason to stay on the older build?
What do you mean when you say that it keeps logging out? The WEB GUI is logging you out or you are loosing connection to the network share?
ynandana
HI Chris,
We were asked to use this particular version, by our team, so we are sticking to it.
WEB GUI is logging me out, its not the internet connection.
-Yash
Chris Moore
OK. Are all the systems on the same network? The thing you describe is not a feature, so It is likely an artifact of something in your network environment. I do need to log back into the GUI about once every day, but it usually only needs to be reconnected more frequently if something interrupts the connection.
