FreeNAS install fail "stopped at kdb_enter+0x3b: movq"
Urukaz
Hello, y am New in Linux, its the first Time for me in freenas and i can't install it. I have use "rufus" for compile the freenas 11.3 ISO in a USB stick, the first stage of installation went well, i reboot the system and it stop at kdb_enter 0x3b : movq $0, as in the photo.
I tested many things, remove a stick of RAM, install on a hard drive instead of ssd, use another usb key and other things.
My hardware is:
AMD FX-8320
MSI 970A-G46
Kingston 4Go 667MHz
Kingston 4Go 800MHz
AMD RX480 Asus Strix 8Go
5* 2To 7200rpm
Kingstons SSDNew300 120Go
Don't hesitate to ask for more information.
For information, i am bad in english.
Can you help me please, i'm lost ? Thanks.
OndrejS
Hi buddy, I had same issue today and it was my flash drive with Installer...try differet flash drive.. it helped me :) good luck
Another idea - try using Etcher to bury the image to the flash drive.
Urukaz
Thanks you very much for your help, I finally succeeded. :)
I had already tried with a lot of flash drive, but the problem did come from there. I just had no luck.
