Freenas Every so often drops network
Raymond Matos
So far this has only happened 3x in the last 2 months. Freenas drops the network the only error i see is "hostname not found".
When the network drops, i can no longer access the GUI, also all the services i have running are also no longer accessible (sabnzbd, sickbeard, plex, etc).
Here are the machine Specs
FreeNAS-9.2.1.7-RELEASE-x64
Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
32631MB
Oct 24 09:00:34 fn9 ntpd_initres[3030]: host name not found: 0.freebsd.pool.ntp.org
Oct 24 09:00:34 fn9 ntpd_initres[3030]: host name not found: 1.freebsd.pool.ntp.org
Oct 24 09:00:34 fn9 ntpd_initres[3030]: host name not found: 2.freebsd.pool.ntp.org
Oct 24 09:16:36 fn9 ntpd_initres[3030]: host name not found: 0.freebsd.pool.ntp.org
Oct 24 09:16:36 fn9 ntpd_initres[3030]: host name not found: 1.freebsd.pool.ntp.org
Oct 24 09:16:36 fn9 ntpd_initres[3030]: host name not found: 2.freebsd.pool.ntp.org
Oct 24 09:32:38 fn9 ntpd_initres[3030]: host name not found: 0.freebsd.pool.ntp.org
Oct 24 09:32:38 fn9 ntpd_initres[3030]: host name not found: 1.freebsd.pool.ntp.org
Oct 24 09:32:38 fn9 ntpd_initres[3030]: host name not found: 2.freebsd.pool.ntp.org
Oct 24 09:48:40 fn9 ntpd_initres[3030]: host name not found: 0.freebsd.pool.ntp.org
Oct 24 09:48:40 fn9 ntpd_initres[3030]: host name not found: 1.freebsd.pool.ntp.org
Oct 24 09:48:40 fn9 ntpd_initres[3030]: host name not found: 2.freebsd.pool.ntp.org
What motherboard are you using? Which NIC?
Mlovelace
Are you up to date on the BIOS revision? Have you tried replacing the data cable or changing the switch port it connects to?
Raymond Matos
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=40098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO>
ether 00:25:90:86:c2:02
inet 192.168.111.30 netmask 0xffffff00 broadcast 192.168.111.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb0: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO>
ether 00:25:90:86:c2:03
status: no carrier
Raymond Matos
Im currently not in the same location as the box, so cant check bios version. The cables are brand new cat6 from monoprice, however i have not tried changing them or the port.
Next time i'm on location i will connect the 2nd NIC as a backup.
Mlovelace
So, your i217LM is going to be the igb0 interface. You could try switching to that link
Cool, learned something new. I was under the impression that all Intel GbE controllers had the same driver - turns out the i210 and i350 (and some older models, presumably their ancestors) are the only ones that use the em driver, while everything else uses igb.
The odd thing is that it's the second case of an i210 acting weird while an i217LM works fine this month.
Raymond Matos
OK so logs are pretty useless. Nothing there. I did however was able to have someone connect the other NIC.
Now should i set that one up with a static, dynamic, or should i setup LAGG?
liveisousb
I had a similar issue where my bge0 adapter was disconnecting every 10 to 30 minutes. I ended up disabling TSO for bge0 adapters with a tunable hw.bge.allow_asf="0". I wonder if it's the same problem with yours?
Raymond Matos
Can anyone recommend how i should connect the secondary NIC. static, dynamic, or should i setup LAGG?
Static or dynamic with a reservation, depending on your network configuration.
Raymond Matos
Seems like it happening again
Nov 10 23:07:07 fn9 afpd[43454]: AFP Replay Cache match: id: 14118 / cmd: AFP_GETEXTATTR
Nov 10 23:07:08 fn9 afpd[43454]: afp_zzz: entering extended sleep
Nov 10 23:07:09 fn9 afpd[99464]: afp_disconnect: primary reconnect succeeded
Nov 11 00:07:02 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 00:07:32 fn9 last message repeated 7 times
Nov 11 00:09:35 fn9 last message repeated 23 times
Nov 11 00:14:52 fn9 last message repeated 73 times
Nov 11 00:14:52 fn9 kernel: (pass18:ahcich4:0:0:0): unable to allocate CCB
Nov 11 00:15:32 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 00:16:02 fn9 last message repeated 7 times
Nov 11 00:18:02 fn9 last message repeated 24 times
Nov 11 00:28:02 fn9 last message repeated 123 times
Nov 11 00:38:02 fn9 last message repeated 150 times
Nov 11 00:48:02 fn9 last message repeated 124 times
Nov 11 00:58:02 fn9 last message repeated 124 times
Nov 11 01:08:02 fn9 last message repeated 125 times
Nov 11 01:18:02 fn9 last message repeated 126 times
Nov 11 01:26:48 fn9 last message repeated 110 times
Nov 11 01:36:47 fn9 last message repeated 5 times
Nov 11 01:41:45 fn9 last message repeated 2 times
Nov 11 01:42:32 fn9 kernel: em0: link state changed to DOWN
Nov 11 01:42:35 fn9 kernel: em0: link state changed to UP
Nov 11 01:42:37 fn9 kernel: em0: link state changed to DOWN
Nov 11 01:43:28 fn9 kernel: em0: link state changed to UP
Nov 11 01:46:48 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 01:47:51 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 01:48:26 fn9 last message repeated 14 times
Nov 11 01:50:31 fn9 last message repeated 49 times
Nov 11 01:51:46 fn9 last message repeated 31 times
Nov 11 01:51:51 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 01:51:51 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 01:51:52 fn9 last message repeated 2 times
Nov 11 01:51:56 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 01:52:31 fn9 last message repeated 14 times
Nov 11 01:54:32 fn9 last message repeated 46 times
Nov 11 01:56:52 fn9 last message repeated 56 times
Nov 11 01:56:57 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 01:56:57 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 01:57:28 fn9 last message repeated 12 times
Nov 11 01:58:08 fn9 last message repeated 17 times
Nov 11 01:58:09 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 01:58:13 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 01:58:18 fn9 last message repeated 3 times
Nov 11 01:58:19 fn9 kernel: sonewconn: pcb 0xfffffe061ab57930: pru_attach() failed
Nov 11 01:58:23 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 01:58:58 fn9 last message repeated 14 times
Nov 11 02:00:18 fn9 last message repeated 33 times
Nov 11 02:00:21 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:00:23 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:00:56 fn9 last message repeated 12 times
Nov 11 02:01:36 fn9 last message repeated 17 times
Nov 11 02:01:37 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:01:41 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:02:01 fn9 last message repeated 9 times
Nov 11 02:02:01 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 02:02:04 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:02:05 fn9 last message repeated 5 times
Nov 11 02:02:06 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:02:06 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:02:07 fn9 last message repeated 3 times
Nov 11 02:02:11 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:02:46 fn9 last message repeated 14 times
Nov 11 02:03:21 fn9 last message repeated 15 times
Nov 11 02:03:24 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:03:25 fn9 kernel: sonewconn: pcb 0xfffffe061ab57930: pru_attach() failed
Nov 11 02:03:26 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:04:01 fn9 last message repeated 14 times
Nov 11 02:04:26 fn9 last message repeated 11 times
Nov 11 02:04:29 fn9 kernel: sonewconn: pcb 0xfffffe061ab57ab8: pru_attach() failed
Nov 11 02:04:31 fn9 last message repeated 7 times
Nov 11 02:04:31 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:05:06 fn9 last message repeated 14 times
Nov 11 02:05:26 fn9 last message repeated 9 times
Nov 11 02:05:30 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:05:31 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:06:06 fn9 last message repeated 14 times
Nov 11 02:06:21 fn9 last message repeated 7 times
Nov 11 02:06:23 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:06:26 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:07:01 fn9 last message repeated 14 times
Nov 11 02:07:06 fn9 last message repeated 3 times
Nov 11 02:07:09 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 02:07:11 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:07:46 fn9 last message repeated 14 times
Nov 11 02:09:51 fn9 last message repeated 50 times
Nov 11 02:11:11 fn9 last message repeated 33 times
Nov 11 02:11:13 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:11:16 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:11:21 fn9 last message repeated 3 times
Nov 11 02:11:22 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:11:26 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:12:01 fn9 last message repeated 14 times
Nov 11 02:12:11 fn9 last message repeated 5 times
Nov 11 02:12:11 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 02:12:16 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:12:51 fn9 last message repeated 14 times
Nov 11 02:13:31 fn9 last message repeated 17 times
Nov 11 02:13:32 fn9 kernel: sonewconn: pcb 0xfffffe061ab57930: pru_attach() failed
Nov 11 02:13:36 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:14:06 fn9 last message repeated 13 times
Nov 11 02:15:31 fn9 last message repeated 34 times
Nov 11 02:15:35 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:15:36 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:16:06 fn9 last message repeated 13 times
Nov 11 02:16:51 fn9 last message repeated 18 times
Nov 11 02:16:54 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:16:56 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:17:11 fn9 last message repeated 7 times
Nov 11 02:17:13 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 02:17:14 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 02:17:16 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:17:51 fn9 last message repeated 14 times
Nov 11 02:18:41 fn9 last message repeated 21 times
Nov 11 02:18:44 fn9 kernel: sonewconn: pcb 0xfffffe061ab57930: pru_attach() failed
Nov 11 02:18:46 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:19:21 fn9 last message repeated 14 times
Nov 11 02:19:46 fn9 last message repeated 11 times
Nov 11 02:19:47 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:19:51 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:20:26 fn9 last message repeated 14 times
Nov 11 02:20:41 fn9 last message repeated 7 times
Nov 11 02:20:42 fn9 kernel: sonewconn: pcb 0xfffffe0546ce1ab8: pru_attach() failed
Nov 11 02:20:46 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Nov 11 02:21:21 fn9 last message repeated 14 times
Nov 11 02:22:16 fn9 last message repeated 23 times
Nov 11 02:22:18 fn9 kernel: sonewconn: pcb 0xfffffe067e901c40: pru_attach() failed
Nov 11 02:22:21 fn9 kernel: sonewconn: pcb 0xfffffe00be550ab8: Listen queue overflow: 25 already in queue awaiting acceptance
Raymond Matos
More info and logs
[root@fn9] /mnt/data1/.system/syslog/log# netstat -m
1024/9986/11010 mbufs in use (current/cache/total)
1023/9107/10130/262144 mbuf clusters in use (current/cache/total/max)
1023/9102 mbuf+clusters out of packet secondary zone in use (current/cache)
0/169/169/131072 4k (page size) jumbo clusters in use (current/cache/total/max)
0/0/0/65536 9k jumbo clusters in use (current/cache/total/max)
0/0/0/32768 16k jumbo clusters in use (current/cache/total/max)
2302K/21386K/23688K bytes allocated to network (current/cache/total)
0/0/0 requests for mbufs denied (mbufs/clusters/mbuf+clusters)
0/0/0 requests for mbufs delayed (mbufs/clusters/mbuf+clusters)
0/0/0 requests for jumbo clusters delayed (4k/9k/16k)
0/0/0 requests for jumbo clusters denied (4k/9k/16k)
0/0/0 sfbufs in use (current/peak/max)
0 requests for sfbufs denied
0 requests for sfbufs delayed
0 requests for I/O initiated by sendfile
0 calls to protocol drain routines
[root@fn9] /mnt/data1/.system/syslog/log# vmstat -z
ITEM                   SIZE  LIMIT     USED     FREE      REQ FAIL SLEEP
UMA Kegs:               208,      0,     282,       7,     282,   0,   0
UMA Zones:              896,      0,     282,       2,     282,   0,   0
UMA Slabs:              568,      0,  231010,       4,  231181,   0,   0
UMA RCntSlabs:          568,      0,    5234,       2,    5234,   0,   0
UMA Hash:               256,      0,      18,      57,      75,   0,   0
6 Bucket:                48,      0,   25542,      18,   25542,   0,   0
8 Bucket:                64,      0,   15249,      39,   15249,   1,   0
12 Bucket:               96,      0,   14075,      23,   14075,   1,   0
16 Bucket:              128,      0,     465,      28,     465,   0,   0
32 Bucket:              256,      0,    4457,      13,    4457,3314,   0
64 Bucket:              512,      0,    1519,       0,    1519, 663,   0
128 Bucket:            1024,      0,    1891,       2,    1891,   0,   0
VM OBJECT:              232,      0,   28340,    2380,  563829,   0,   0
MAP:                    232,      0,       8,      24,       8,   0,   0
KMAP ENTRY:             120, 1037601,      85,     287,  239551,   0,   0
MAP ENTRY:              120,      0,    9789,    1681, 1630215,   0,   0
fakepg:                 120,      0,       0,       0,       0,   0,   0
mt_zone:               4112,      0,     348,       0,     348,   0,   0
16:                      16,      0,  161295,    1497, 5843136,   0,   0
32:                      32,      0,  487033,    2413, 9103417,   0,   0
64:                      64,      0,  137114,   40014, 6706321,   0,   0
128:                    128,      0,  141270,   22000, 9599957,   0,   0
256:                    256,      0,   39018,   58407, 4867530,   0,   0
512:                    512,      0,    1622,   20771, 2385584,   0,   0
1024:                  1024,      0,    8917,      59, 1024929,   0,   0
2048:                  2048,      0,    9587,      51,   42338,   0,   0
4096:                  4096,      0,    4921,      41,  119551,   0,   0
8192:                  8192,      0,      43,      18,   54393,   0,   0
16384:                16384,      0,      44,      11,    5503,   0,   0
32768:                32768,      0,      89,      17,    1824,   0,   0
65536:                65536,      0,      36,      12,   24148,   0,   0
131072:              131072,      0,      33,      19,    2384,   0,   0
Files:                   80,      0,     837,     468, 6478734,   0,   0
TURNSTILE:              136,      0,    1237,      43,    1237,   0,   0
rl_entry:                40,      0,     219,     117,     219,   0,   0
umtx pi:                 96,      0,       0,       0,       0,   0,   0
MAC labels:              40,      0,       0,       0,       0,   0,   0
PROC:                  1192,      0,     252,      24,   23482,   0,   0
THREAD:                1160,      0,    1155,      81,   11414,   0,   0
SLEEPQUEUE:              80,      0,    1237,      39,    1237,   0,   0
VMSPACE:                392,      0,     104,      76,   23333,   0,   0
cpuset:                  72,      0,     767,     133,    1972,   0,   0
audit_record:           976,      0,       0,       0,       0,   0,   0
mbuf_packet:            256,      0,    1023,    9102, 3831972,   0,   0
mbuf:                   256,      0,       2,     883, 8699895,   0,   0
mbuf_cluster:          2048, 262144,   10125,       5,   10159,   0,   0
mbuf_jumbo_page:       4096, 131072,       0,     169, 2276068,   0,   0
mbuf_jumbo_9k:         9216,  65536,       0,       0,       0,   0,   0
mbuf_jumbo_16k:       16384,  32768,       0,       0,       0,   0,   0
mbuf_ext_refcnt:          4,      0,       0,       0,       0,   0,   0
NetGraph items:          72,   4118,       0,     116,       6,   0,   0
NetGraph data items:     72,    522,       0,       0,       0,   0,   0
ttyinq:                 160,      0,    1303,      41,    1674,   0,   0
ttyoutq:                256,      0,     680,      25,     872,   0,   0
g_bio:                  248,      0,       0,     825, 6092244,   0,   0
icl_conn:               152,      0,       0,       0,       0,   0,   0
icl_pdu:                 80,      0,       0,       0,       0,   0,   0
ata_request:            328,      0,       0,       0,       0,   0,   0
ata_composite:          336,      0,       0,       0,       0,   0,   0
iscsi_outstanding:       40,      0,       0,       0,       0,   0,   0
cryptop:                 88,      0,       0,     168,     263,   0,   0
cryptodesc:              72,      0,       0,     200,     263,   0,   0
vtnet_tx_hdr:            24,      0,       0,       0,       0,   0,   0
FPU_save_area:          832,      0,       0,       0,       0,   0,   0
beio:                   360,      0,       0,       0,       0,   0,   0
cfi_lun:                344,      0,       0,       0,       0,   0,   0
cfi_metatask:           320,      0,       0,       0,       0,   0,   0
cfiscsi_data_wait:       56,      0,       0,       0,       0,   0,   0
VNODE:                  504,      0,   58959,    2033,   89432,   0,   0
VNODEPOLL:              112,      0,       1,      32,       1,   0,   0
S VFS Cache:            108,      0,   31910,    2278, 6491347,   0,   0
STS VFS Cache:          148,      0,       0,       0,       0,   0,   0
L VFS Cache:            328,      0,    9083,     637,   16095,   0,   0
LTS VFS Cache:          368,      0,       0,       0,       0,   0,   0
NAMEI:                 1024,      0,       0,      32,10565549,   0,   0
DIRHASH:               1024,      0,      61,       7,      61,   0,   0
NCLNODE:                568,      0,       0,       0,       0,   0,   0
Mountpoints:            824,      0,      57,       7,      63,   0,   0
pipe:                   728,      0,      39,      46,   20866,   0,   0
AIO:                    208,      0,       0,       0,       0,   0,   0
AIOP:                    32,      0,       0,       0,       0,   0,   0
AIOCB:                  480,      0,       0,       0,       0,   0,   0
AIOL:                   128,      0,       0,       0,       0,   0,   0
AIOLIO:                 272,      0,       0,       0,       0,   0,   0
ksiginfo:               112,      0,     262,     794,    3538,   0,   0
itimer:                 344,      0,       1,      10,       1,   0,   0
KNOTE:                  128,      0,      64,     255,  809811,   0,   0
bridge_rtnode:           64,      0,      26,     198,      54,   0,   0
socket:                 680, 262146,     256,     698,   44269,   0,   0
unpcb:                  240, 262144,     116,     124,   12353,   0,   0
ipq:                     56,   8253,       0,       0,       0,   0,   0
udp_inpcb:              392, 262150,      30,      30,    1187,   0,   0
udpcb:                   16, 262248,      30,     474,    1187,   0,   0
tcp_inpcb:              392, 262150,      30,      50,     314,   0,   0
tcpcb:                  976, 262144,      30,      26,     314,   0,   0
tcptw:                   72,  27800,       0,     100,       7,   0,   0
syncache:               152,  15375,       0,     100,     237,   0,   0
hostcache:              136,  15372,       3,      53,       3,   0,   0
tcpreass:                40,  16464,       0,      84,       6,   0,   0
sackhole:                32,      0,       0,       0,       0,   0,   0
ripcb:                  392, 262150,       0,      30,       5,   0,   0
rtentry:                200,      0,      13,      63,      13,   0,   0
IPFW dynamic rule:      120,   4123,       0,       0,       0,   0,   0
divcb:                  392, 262150,       0,       0,       0,   0,   0
selfd:                   56,      0,     491,     643, 2475812,   0,   0
SWAPMETA:               288, 4051710,       0,       0,       0,   0,   0
FFS inode:              168,      0,    4727,      91,    6583,   0,   0
FFS1 dinode:            128,      0,    3453,      85,    3510,   0,   0
FFS2 dinode:            256,      0,    1274,      91,    3073,   0,   0
md0:                    512,      0,    7219,      12,    7221,   0,   0
md1:                    512,      0,      92,      13,      92,   0,   0
md2:                    512,      0,   90043,    4128,   96331,   0,   0
g_stripe_zone:       131072,    100,       0,       0,       0,   0,   0
taskq_zone:              48,      0,       0,     720,   21488,   0,   0
range_seg_cache:         64,      0,   13460,    4012,  364672,   0,   0
zio_cache:              920,      0,       4,  166088,13824246,   0,   0
zio_link_cache:          48,      0,       0,  166392, 9162656,   0,   0
zio_buf_512:            512,      0,   43328,    2039,   74156,   0,   0
zio_data_buf_512:       512,      0,    1868,      15,    9751,   0,   0
zio_buf_1024:          1024,      0,     481,      15,    4856,   0,   0
zio_data_buf_1024:     1024,      0,    1021,      11,    5026,   0,   0
zio_buf_1536:          1536,      0,     247,      11,     577,   0,   0
zio_data_buf_1536:     1536,      0,     556,      18,     954,   0,   0
zio_buf_2048:          2048,      0,     206,      10,   17833,   0,   0
zio_data_buf_2048:     2048,      0,     406,      16,    3089,   0,   0
zio_buf_4096:          4096,      0,     361,    1055,  412642,   0,   0
zio_data_buf_4096:     4096,      0,    1280,     454,    9574,   0,   0
zio_buf_8192:          8192,      0,      52,      78,   34279,   0,   0
zio_data_buf_8192:     8192,      0,    1192,    1260,    6198,   0,   0
zio_buf_12288:        12288,      0,      50,      48,   34722,   0,   0
zio_data_buf_12288:   12288,      0,     692,     477,    3827,   0,   0
zio_buf_16384:        16384,      0,   19480,     152,  193988,   0,   0
zio_data_buf_16384:   16384,      0,     656,     308,    9195,   0,   0
zio_buf_20480:        20480,      0,      13,      31,    7876,   0,   0
zio_data_buf_20480:   20480,      0,     401,      16,    2068,   0,   0
zio_buf_24576:        24576,      0,      10,      32,    9990,   0,   0
zio_data_buf_24576:   24576,      0,     348,       9,    1604,   0,   0
zio_buf_28672:        28672,      0,       1,      36,   10273,   0,   0
zio_data_buf_28672:   28672,      0,     243,      17,     986,   0,   0
zio_buf_32768:        32768,      0,       8,      35,    5454,   0,   0
zio_data_buf_32768:   32768,      0,     147,      10,     583,   0,   0
zio_buf_36864:        36864,      0,      11,      33,    8694,   0,   0
zio_data_buf_36864:   36864,      0,     156,       8,    1028,   0,   0
zio_buf_40960:        40960,      0,       1,      81,    3078,   0,   0
zio_data_buf_40960:   40960,      0,     121,       8,     893,   0,   0
zio_buf_45056:        45056,      0,       7,      97,    2137,   0,   0
zio_data_buf_45056:   45056,      0,     131,       7,    9408,   0,   0
zio_buf_49152:        49152,      0,       0,      67,   14407,   0,   0
zio_data_buf_49152:   49152,      0,      76,       8,     349,   0,   0
zio_buf_53248:        53248,      0,       0,      91,    8126,   0,   0
zio_data_buf_53248:   53248,      0,     100,       7,     384,   0,   0
zio_buf_57344:        57344,      0,       0,     187,    9300,   0,   0
zio_data_buf_57344:   57344,      0,      71,       7,     290,   0,   0
zio_buf_61440:        61440,      0,       0,      17,    1103,   0,   0
zio_data_buf_61440:   61440,      0,     101,       8,     449,   0,   0
zio_buf_65536:        65536,      0,       0,   41168,  601223,   0,   0
zio_data_buf_65536:   65536,      0,      65,       8,     368,   0,   0
zio_buf_69632:        69632,      0,       0,      71,  368682,   0,   0
zio_data_buf_69632:   69632,      0,      57,       8,     335,   0,   0
zio_buf_73728:        73728,      0,       0,      23,   14605,   0,   0
zio_data_buf_73728:   73728,      0,      54,       7,     539,   0,   0
zio_buf_77824:        77824,      0,       0,      20,    6797,   0,   0
zio_data_buf_77824:   77824,      0,      35,       8,     310,   0,   0
zio_buf_81920:        81920,      0,       0,      23,    1831,   0,   0
zio_data_buf_81920:   81920,      0,      63,      15,     461,   0,   0
zio_buf_86016:        86016,      0,       0,      32,    1422,   0,   0
zio_data_buf_86016:   86016,      0,      32,       8,     324,   0,   0
zio_buf_90112:        90112,      0,       0,      21,     960,   0,   0
zio_data_buf_90112:   90112,      0,      42,       9,     360,   0,   0
zio_buf_94208:        94208,      0,       0,      21,    1045,   0,   0
zio_data_buf_94208:   94208,      0,      59,       9,     284,   0,   0
zio_buf_98304:        98304,      0,       0,      21,     942,   0,   0
zio_data_buf_98304:   98304,      0,      41,       7,     248,   0,   0
zio_buf_102400:      102400,      0,       0,      96,    1001,   0,   0
zio_data_buf_102400: 102400,      0,      25,       7,     226,   0,   0
zio_buf_106496:      106496,      0,       0,      36,     757,   0,   0
zio_data_buf_106496: 106496,      0,      35,      12,     440,   0,   0
zio_buf_110592:      110592,      0,       0,      28,     728,   0,   0
zio_data_buf_110592: 110592,      0,      59,       7,     396,   0,   0
zio_buf_114688:      114688,      0,       0,      31,    1079,   0,   0
zio_data_buf_114688: 114688,      0,      26,       9,     335,   0,   0
zio_buf_118784:      118784,      0,       0,      16,     466,   0,   0
zio_data_buf_118784: 118784,      0,      15,      10,     197,   0,   0
zio_buf_122880:      122880,      0,       0,      32,    1115,   0,   0
zio_data_buf_122880: 122880,      0,      48,      10,     256,   0,   0
zio_buf_126976:      126976,      0,       0,      18,    6482,   0,   0
zio_data_buf_126976: 126976,      0,      12,       8,     189,   0,   0
zio_buf_131072:      131072,      0,      10,    7807,  511808,   0,   0
zio_data_buf_131072: 131072,      0,  109852,   19260,  527991,   0,   0
lz4_ctx:              16384,      0,       0,      18,  471835,   0,   0
sa_cache:                80,      0,   37790,    2125,   58947,   0,   0
dnode_t:                872,      0,   48549,    1035,  122800,   0,   0
dmu_buf_impl_t:         224,      0,  157520,   23054,  456372,   0,   0
arc_buf_hdr_t:          216,      0,  289957,      41,  417405,   0,   0
arc_buf_t:               72,      0,  145654,   19746,  430497,   0,   0
zil_lwb_cache:          192,      0,      13,     647,   11578,   0,   0
zfs_znode_cache:        368,      0,   37790,    2040,   58947,   0,   0
cyclic_id_cache:         64,      0,       0,       0,       0,   0,   0
dtrace_state_cache:    4096,      0,       0,       0,       0,   0,   0
taskq_zone:              48,      0,       0,       0,       0,   0,   0
udp_inpcb:              392, 262150,       2,      38,    1418,   0,   0
udpcb:                   16, 262248,       2,     502,    1418,   0,   0
tcp_inpcb:              392, 262150,       6,      34,      11,   0,   0
tcpcb:                  976, 262144,       6,      14,      11,   0,   0
tcptw:                   72,  27800,       0,       0,       0,   0,   0
syncache:               152,  15375,       0,       0,       0,   0,   0
hostcache:              136,  15372,       0,       0,       0,   0,   0
tcpreass:                40,  16464,       0,     252,      22,   0,   0
ripcb:                  392, 262150,       0,       0,       0,   0,   0
rtentry:                200,      0,      13,      44,      14,   0,   0
udp_inpcb:              392, 262150,       6,     134,     807,   0,   0
udpcb:                   16, 262248,       6,     498,     807,   0,   0
tcp_inpcb:              392, 262150,      20,     180,    1246,   0,   0
tcpcb:                  976, 262144,      17,     151,    1246,   0,   0
tcptw:                   72,  27800,       3,     247,     387,   0,   0
syncache:               152,  15375,       0,     100,     450,   0,   0
hostcache:              136,  15372,      23,      61,      80,   0,   0
tcpreass:                40,  16464,       0,    2100,   15436,   0,   0
rtentry:                200,      0,      13,      63,      14,   0,   0
udp_inpcb:              392, 262150,       2,      38,      26,   0,   0
udpcb:                   16, 262248,       2,     502,      26,   0,   0
tcp_inpcb:              392, 262150,       4,      36,      12,   0,   0
tcpcb:                  976, 262144,       4,      12,      12,   0,   0
tcptw:                   72,  27800,       0,      50,       1,   0,   0
syncache:               152,  15375,       0,      25,       3,   0,   0
hostcache:              136,  15372,       0,      28,       1,   0,   0
tcpreass:                40,  16464,       0,       0,       0,   0,   0
udp_inpcb:              392, 262150,       2,      28,      28,   0,   0
udpcb:                   16, 262248,       2,     502,      28,   0,   0
tcp_inpcb:              392, 262150,       6,      34,      71,   0,   0
tcpcb:                  976, 262144,       6,      18,      71,   0,   0
tcptw:                   72,  27800,       0,     100,       3,   0,   0
syncache:               152,  15375,       0,      75,      70,   0,   0
hostcache:              136,  15372,      14,      70,      36,   0,   0
tcpreass:                40,  16464,       0,     168,      12,   0,   0
udp_inpcb:              392, 262150,      14,      56,    7655,   0,   0
udpcb:                   16, 262248,      14,     490,    7655,   0,   0
tcp_inpcb:              392, 262150,      15,    1355,   19014,   0,   0
tcpcb:                  976, 262144,      13,      43,   19014,   0,   0
tcptw:                   72,  27800,       2,    1448,    5988,   0,   0
syncache:               152,  15375,       0,     150,    9189,   0,   0
hostcache:              136,  15372,      15,      69,      50,   0,   0
udp_inpcb:              392, 262150,       2,      38,      38,   0,   0
udpcb:                   16, 262248,       2,     502,      38,   0,   0
tcp_inpcb:              392, 262150,       2,      28,      10,   0,   0
tcpcb:                  976, 262144,       2,      10,      10,   0,   0
Raymond Matos
And the boot log
[root@fn9] /mnt/data1/.system/syslog/log# cat /var/run/dmesg.boot
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE-p10 #0 r262572+4fb5adc: Wed Aug  6 17:07:16 PDT 2014
    root@build3.ixsystems.com:/fusion/jkh/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz (3200.07-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x306c3  Family = 0x6  Model = 0x3c  Stepping = 3
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x21<LAHF,ABM>
  Standard Extended Features=0x2fbb<GSFSBASE,TSCADJ,SMEP,ENHMOVSB,INVPCID>
  TSC: P-state invariant, performance statistics
real memory  = 34376515584 (32784 MB)
avail memory = 33051303936 (31520 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  2
cpu2 (AP): APIC ID:  4
cpu3 (AP): APIC ID:  6
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of 67, 1 (4) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
Event timer "HPET3" frequency 14318180 Hz quality 440
Event timer "HPET4" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 1.1 on pci0
pci2: <ACPI PCI bus> on pcib2
mps0: <LSI SAS2008> port 0xe000-0xe0ff mem 0xf7cc0000-0xf7cc3fff,0xf7c80000-0xf7cbffff irq 17 at device 0.0 on pci2
mps0: Firmware: 15.00.00.00, Driver: 16.00.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf7400000-0xf77fffff,0xe0000000-0xefffffff irq 16 at device 2.0 on pci0
pci0: <multimedia, HDA> at device 3.0 (no driver attached)
pci0: <simple comms> at device 22.0 (no driver attached)
pci0: <simple comms, UART> at device 22.3 (no driver attached)
em0: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0xf060-0xf07f mem 0xf7d00000-0xf7d1ffff,0xf7d2d000-0xf7d2dfff irq 20 at device 25.0 on pci0
em0: Using an MSI interrupt
em0: Ethernet address: 00:25:90:86:c2:02
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7d2c000-0xf7d2c3ff irq 16 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci4: <ACPI PCI bus> on pcib4
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xd000-0xd01f mem 0xf7b00000-0xf7b7ffff,0xf7b80000-0xf7b83fff irq 19 at device 0.0 on pci4
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: 00:25:90:86:c2:03
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib5: <ACPI PCI-PCI bridge> irq 17 at device 28.5 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> at device 0.0 on pci5
pci6: <ACPI PCI bus> on pcib6
fwohci0: <Texas Instruments TSB43AB22/A> mem 0xf7a04000-0xf7a047ff,0xf7a00000-0xf7a03fff irq 16 at device 3.0 on pci6
fwohci0: OHCI version 1.10 (ROM=1)
fwohci0: No. of Isochronous channels is 4.
fwohci0: EUI64 00:30:48:00:00:10:9c:dd
fwohci0: Phy 1394a available S400, 2 ports.
fwohci0: Link S400, max_rec 2048 bytes.
firewire0: <IEEE1394(FireWire) bus> on fwohci0
sbp0: <SBP-2/SCSI over FireWire> on firewire0
fwohci0: Initiate bus reset
fwohci0: fwohci_intr_core: BUS reset
fwohci0: fwohci_intr_core: node_id=0x00000000, SelfID Count=1, CYCLEMASTER mode
pcib7: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
pci7: <ACPI PCI bus> on pcib7
pci7: <serial bus, USB> at device 0.0 (no driver attached)
pcib8: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0
pci8: <ACPI PCI bus> on pcib8
ahci0: <ASMedia ASM1061 AHCI SATA controller> port 0xc050-0xc057,0xc040-0xc043,0xc030-0xc037,0xc020-0xc023,0xc000-0xc01f mem 0xf7800000-0xf78001ff irq 19 at device 0.0 on pci8
ahci0: AHCI v1.20 with 2 6Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7d2b000-0xf7d2b3ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci1: <Intel Lynx Point AHCI SATA controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf040-0xf05f mem 0xf7d2a000-0xf7d2a7ff irq 19 at device 31.2 on pci0
ahci1: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
pci0: <dasp> at device 31.6 (no driver attached)
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
orm0: <ISA Option ROMs> at iomem 0xcf000-0xd4fff,0xd5000-0xd5fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
firewire0: 1 nodes, maxhop <= 0 cable IRM irm(0)  (me)
firewire0: bus manager 0
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe00082d1d80 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub0: 3 ports with 3 removable, self powered
uhub1: 3 ports with 3 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.04, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.04, addr 2> on usbus1
uhub2: 6 ports with 6 removable, self powered
uhub3: 8 ports with 8 removable, self powered
ugen1.3: <No brand> at usbus1
ukbd0: <No brand KVM, class 0/0, rev 1.10/0.00, addr 3> on usbus1
kbd2 at ukbd0
ums0: <No brand KVM, class 0/0, rev 1.10/0.00, addr 3> on usbus1
ums0: 5 buttons and [XYZ] coordinates ID=1
ugen1.4: <Prolific Technology Inc.> at usbus1
uplcom0: <Prolific Technology Inc. USB-Serial Controller D, class 0/0, rev 1.10/4.00, addr 4> on usbus1
ugen0.3: <PNY Technologies> at usbus0
umass0: <PNY Technologies USB 2.0 FD, class 0/0, rev 2.00/11.00, addr 3> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0x0100
umass0:11:0:-1: Attached to scbus11
ses0 at mps0 bus 0 scbus0 target 8 lun 0
ses0: <HP HP SAS EXP Card 2.06> Fixed Enclosure Services SCSI-5 device
ses0: Serial Number RF15BP1783
ses0: 600.000MB/s transfers
ses0: Command Queueing enabled
ses0: SCSI-3 ENC Device
ada0 at ahcich4 bus 0 scbus6 target 0 lun 0
ada0: <KINGSTON SV300S37A120G 505ABBF0> ATA-8 SATA 3.x device
ada0: Serial Number 50026B723109F1BB
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 114473MB (234441648 512 byte sectors: 16H 63S/T 16383C)
ada0: Previously was known as ad12
da0 at mps0 bus 0 scbus0 target 9 lun 0
da0: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da0: Serial Number      WD-WCC4N0524760
da0: 150.000MB/s transfers
da0: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da0: quirks=0x8<4K>
da1 at mps0 bus 0 scbus0 target 10 lun 0
da1: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da1: Serial Number      WD-WMC4N1402109
da1: 150.000MB/s transfers
da1: Command Queueing enabled
da1: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da1: quirks=0x8<4K>
da2 at mps0 bus 0 scbus0 target 11 lun 0
da2: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da2: Serial Number      WD-WMC4N1438408
da2: 150.000MB/s transfers
da2: Command Queueing enabled
da2: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da2: quirks=0x8<4K>
da3 at mps0 bus 0 scbus0 target 12 lun 0
da3: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da3: Serial Number      WD-WCC4N0477167
da3: 150.000MB/s transfers
da3: Command Queueing enabled
da3: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da3: quirks=0x8<4K>
da7 at mps0 bus 0 scbus0 target 16 lun 0
da7: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da7: Serial Number      WD-WCC4N0977911
da7: 150.000MB/s transfers
da7: Command Queueing enabled
da7: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da7: quirks=0x8<4K>
da8 at mps0 bus 0 scbus0 target 17 lun 0
da8: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da8: Serial Number      WD-WCC4N0974431
da8: 150.000MB/s transfers
da8: Command Queueing enabled
da8: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da8: quirks=0x8<4K>
da9 at mps0 bus 0 scbus0 target 18 lun 0
da9: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da9: Serial Number      WD-WMC4N1326581
da9: 150.000MB/s transfers
da9: Command Queueing enabled
da9: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da9: quirks=0x8<4K>
da10 at mps0 bus 0 scbus0 target 19 lun 0
da10: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device
da10: Serial Number      WD-WMC4N1613915
da10: 150.000MB/s transfers
da10: Command Queueing enabled
da10: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da10: quirks=0x8<4K>
da4 at mps0 bus 0 scbus0 target 13 lun 0
da4: <ATA WDC WD5000AVDS-7 0A01> Fixed Direct Access SCSI-6 device
da4: Serial Number      WD-WCAV9R143154
da4: 150.000MB/s transfers
da4: Command Queueing enabled
da4: 476940MB (976773168 512 byte sectors: 255H 63S/T 60801C)
da5 at mps0 bus 0 scbus0 target 14 lun 0
da5: <ATA ST2000DL004 HD20 0001> Fixed Direct Access SCSI-6 device
da5: Serial Number S2H7J90C623358
da5: 150.000MB/s transfers
da5: Command Queueing enabled
da5: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C)
da5: quirks=0x8<4K>
da6 at mps0 bus 0 scbus0 target 15 lun 0
da6: <ATA ST2000DL004 HD20 0001> Fixed Direct Access SCSI-6 device
da6: Serial Number S2H7J90C623353
da6: 150.000MB/s transfers
da6: Command Queueing enabled
da6: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C)
da6: quirks=0x8<4K>
da16 at umass-sim0 bus 0 scbus11 target 0 lun 0
da16: <PNY USB 2.0 FD 1100> Removable Direct Access SCSI-4 device
da16: Serial Number ACC7HD1000000019
da16: 40.000MB/s transfers
da16: 7788MB (15950592 512 byte sectors: 255H 63S/T 992C)
da16: quirks=0x2<NO_6_BYTE>
da11 at mps0 bus 0 scbus0 target 20 lun 0
da11: <ATA WDC WD5000AADS-0 0A01> Fixed Direct Access SCSI-6 device
da11: Serial Number      WD-WMAV90620268
da11: 150.000MB/s transfers
da11: Command Queueing enabled
da11: 476940MB (976773168 512 byte sectors: 255H 63S/T 60801C)
da15 at mps0 bus 0 scbus0 target 24 lun 0
da15: <ATA WDC WD20EARS-00M AB51> Fixed Direct Access SCSI-6 device
da15: Serial Number      WD-WCAZA8972287
da15: 150.000MB/s transfers
da15: Command Queueing enabled
da15: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C)
da15: quirks=0x8<4K>
da13 at mps0 bus 0 scbus0 target 22 lun 0
da13: <ATA WDC WD20EARS-00M AB51> Fixed Direct Access SCSI-6 device
da13: Serial Number      WD-WCAZA8973495
da13: 150.000MB/s transfers
da13: Command Queueing enabled
da13: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C)
da13: quirks=0x8<4K>
da12 at mps0 bus 0 scbus0 target 21 lun 0
da12: <ATA WDC WD20EARS-00M AB51> Fixed Direct Access SCSI-6 device
da12: Serial Number      WD-WCAZA8996777
da12: 150.000MB/s transfers
da12: Command Queueing enabled
da12: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C)
da12: quirks=0x8<4K>
da14 at mps0 bus 0 scbus0 target 23 lun 0
da14: <ATA WDC WD20EARS-00M AB51> Fixed Direct Access SCSI-6 device
da14: Serial Number      WD-WCAZA4928373
da14: 150.000MB/s transfers
da14: Command Queueing enabled
da14: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C)
da14: quirks=0x8<4K>
cd0 at ahcich2 bus 0 scbus4 target 0 lun 0
cd0: <Optiarc DVD RW AD-7670S 1.02> Removable CD-ROM SCSI-0 device
cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present
ses0: pass1,da0: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: SATA device
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c0
ses0: pass4,da3: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c1
ses0: pass2,da1: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c2
ses0: pass3,da2: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c3
ses0: pass8,da7: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c4
ses0: pass9,da8: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c5
ses0: pass10,da9: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c6
ses0: pass11,da10: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8c7
ses0: pass13,da12: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8cc
ses0: pass15,da14: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8cd
ses0: pass14,da13: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8ce
ses0: pass16,da15: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8cf
ses0: pass12,da11: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8d0
ses0: pass5,da4: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8d1
ses0: pass6,da5: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8d2
ses0: pass7,da6: SAS Device Slot Element: 1 Phys at Slot 0
ses0:  phy 0: parent 500143801442e8e6 addr 500143801442e8d3
SMP: AP CPU #2 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
Timecounter "TSC-low" frequency 1600034926 Hz quality 1000
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
WARNING: /data was not properly dismounted
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_ELI: Device da1p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:     Crypto: hardware
GEOM_ELI: Device da0p1.eli created.
GEOM_ELI: Device da2p1.eli created.
GEOM_ELI: Device da3p1.eli created.
GEOM_ELI: Device da8p1.eli created.
GEOM_ELI: Device da9p1.eli created.
GEOM_ELI: Device da10p1.eli created.
GEOM_ELI: Device da4p1.eli created.
GEOM_ELI: Device da5p1.eli created.
GEOM_ELI: Device da6p1.eli created.
GEOM_ELI: Device da11p1.eli created.
GEOM_ELI: Device da7p1.eli created.
GEOM_ELI: Device da12p1.eli created.
GEOM_ELI: Device da13p1.eli created.
GEOM_ELI: Device da14p1.eli created.
GEOM_ELI: Device da15p1.eli created.
The errors from post #16 make me think your hardware is bad. Maybe an RMA of the motherboard?
That's all I have for ideas though. :/
