Freenas crashing during scrub
Kilgurin
My freenas box has started to randomly crash while it is scrubbing my pool and I'm not sure what to make of the logs. The last time I ran smart tests and scrubbed the drives in the pool were fine. The logs are here https://docs.google.com/document/d/1xdH1bm2FgSdZJcT6AyD-zHnWEnh56gSickWvURAqrxA/edit?usp=drivesdk
Edit for specs
Freenas 11.1 stable
I7 970 ( 3.2 GHz 6 core)
4gB x 3 (12gB) ddr3
4tB x 8 wd red 5400k drives using raid-z2
Boot drive on 2 mirrored 8gB San disk cruzer thumb drives
Asus p6td deluxe
Corsair rm 750w psu
StarTech.com 4 Port PCI SATA RAID Controller Adapter Card PCISATA4R1
Snow
What are your system spec's ?
I do not mean to be a bad news bear but please read the Forum Rules.
Not that some one will not help you. It just may help you get a faster Response.
D
dlavigne
Guest
This looks like the issue:
May 1 00:53:29 freenas swap_pager: indefinite wait buffer: bufobj: 0, blkno: 526952, size: 45056
To clarify, which exact version of FreeNAS (eg is it 11.1-U7)?
Kilgurin
Sorry, I am on version
FreeNAS-11.1-U6 heres an attached debug
  • debug-freenas-20190614111140.tgz
saurav
I too started having this issue two days back! I'm on 11.1U7, HP N36L, 8GB ECC RAM, 4x4TB RAID-Z2.
My logs: https://pastebin.com/2nFU3rz4
I have removed ~14000 lines of "swap_pager_getswapspace(2): failed” lines to comply with pastebin’s size limit.
This is the first time it has happened. This machine has no services or sharing running, other than ssh & rsync. Its just hosts the replicas of the primary server.
saurav
While looking through my debug logs, I found a panic.txt file which has this
I/O to pool 'tank' appears to be hung on vdev guid 3927753159453926719 at '/dev/gptid/1ae22a85-f7d5-11e8-872b-68b59972b65f'.
This is on a new'ish (5+ months old) Seagate Ironwolf I'd replaced a failed WD-RED with.
Snow
@saurav no need to paste bin it just drop it in the texts window and it will show up like this.
  • debug-freenas-20190613230841.tgz
