FreeNAS crash, have to manual reboot
soulaero
My FreeNAS crashed this morning again, on consolo, I can input 13 (roboot), then 'enter', but system just hang on, no any response then. I have to reboot it manually. System has an issue at around 09:00:00, I rebooted it at 09:28:46
There is no any related logsin /var/log/messages,
Apr 5 01:10:03 freenas update_check.py: [freenasOS.Configuration:612] Got http
error HTTP Error 404: Not Found
Apr 6 00:00:00 freenas syslog-ng[1844]: Configuration reload request received,reloading configuration;
Apr 6 09:28:46 freenas syslog-ng[1934]: syslog-ng starting up; version='3.5.6'
Apr 6 09:28:46 freenas Copyright (c) 1992-2014 The FreeBSD Project.
Apr 6 09:28:46 freenas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991,1992, 1993, 1994
There is no dump files in /data/crash.
Since it has happened more than twice, what can I do to detect the issue? Freenas version is FreeNAS-9.3-STABLE-201602031011
If its hanging, that's not a crash. A crash is a kernel panic, which you aren't getting. So claiming it is a crash is incorrect.
I'm betting you have some kind of ACPI issue. Can you post your hardware specs?
soulaero
It's a HP DL 120 G7
CPU: E3-1270
MEM: 12GB
Harddisk: 4* WD20EARS , 2*2 Mirror
Yeah, I'm not sure if it's an hardware issue.
Yeah.. can't help with that. No experience with HP on FreeNAS.
