Nitrobuggies
- Oct 18, 2015
Hey,
I am hoping you guys can answer my questions. Been trying to do a fair bit of research, and narrowed most things down to a few options. Just want some expert opinions on it, as well as if what i wish to do is possible or even the correct way to do it. I live in Australia if that helps, finding some parts is proving tricky, but do able.
So I am looking at building myself a NAS box. Finally gotten sick of not having a proper solution in place. It will be used for local backups of my Macbook Pro (time machine?), and a Surface Pro 3. So if something happened we had a local backup of the device/hdd. We already backup important data to an external drive and cloud storage, But i want something that will also backup the whole computer, so if something happens to one of the devices we can get a replacement and get it going again as if nothing happened. As well as storage for all of our media (movies, Tv Shows, Pictures etc). It will be streaming media to a few different devices, 1 PC, 2 Rokus, iPad, Macbook, Surface. At most maybe 2-3 streams at a time. I have a few more questions relating to what i can get FreeNAS to do, but will save them for later once i work out hardware first.
For the Hardware I'm stuck between two choices for MB/CPU. I already know to make sure i get whatever RAM is suggested by the MB manufacture. Looking at using either HGST or WD Red drives, depending what i can get at a good price at the time.
System Config:
MB: X10SLH-F or X10sl7-F - Not sure between the two. Price difference isn't to high
CPU: Intel G3258
System Config 2:
MB: AsRock C2750D4i
Both systems would have the following
RAM: 16gb ECC ram from the verified list for the MB
HDD: 6 3TB WD Red/HGST
OS: Been reading a few people suggest not to use a USB stick and instead use a SSD. I have an old SSD in my HTPC which i could use, or can always get one. Any suggestions on what to get, for example certain size?
Case: Fractal Design R5
PSU: 400w Bronze certified, depending on whats offered from where ever i get the parts from. Always had good success from Silverstone, Corsair, Antec
Also looking at a UPS. But haven't done much research so far.
Thank you for any help. I know most of this has most likely been asked before, i tried a quick search and have been lurking on these forums for the past few weeks, trying to read and understand as much as possible.
System Config:
CPU: Intel G3258
System Config 2:
MB: AsRock C2750D4i
