Hey all
I've been playing around with FreeNAS I've set it up with the following to try
Intel core 2 duo e8600
6gb ddr 2 ( I think it's only using 4gb)
3 5tb hardrives with about 9.8gb of usable storage
16gb USB boot drive
I'm using this for
Plex server
2 time machine backups
2 windows backups (all on daily backups)
Storing Plex media movies tv shows and a iTunes library
I know this isn't the most ideal setup but I just wanted, and I was using stuff I had laying around just wanted try it out and it does work.
I'm wondering if someone could suggest a build that would suit my use case?
Thanks
16gb USB boot drive
I'm using this for
Plex server
Thanks
