borkborkbork
- Jun 16, 2012
I had a FreeNAS box, with 2 drives hooked up to it, a WD15EADS (/WD1.5TB) and a WD20EARS (/WD2TB). Both are in ZFS format. Was working great until I woke up this morning and the box had crashed. I tried rebooting, but it went into a panic and froze while booting. I unhooked the 2 drives, and it still wouldn't boot, so I figured that the USB was dead. I got out anotehr USB stick and put FreeNAS onot that, thinking I'll just import the two drives back in.
Tried auto import, didn't work (I'll post the fail message at the end). I then entered the Shell and tried zpool list, and both came out healthy. So I scrubbed them and tried again. Still nothing. I then tried zpool import -f, and it tells me that it can't create a mountpoint. Is there anything else I can do?
IndexError at /storage/auto-import/
list index out of range
Request Method: GET
Request URL: http://192.168.1.6/storage/auto-import/
Django Version: 1.3.1
Exception Type: IndexError
Exception Value:
Exception Location: /usr/local/www/freenasUI/middleware/notifier.py in detect_volumes, line 1608
Python Executable: /usr/local/bin/python
Python Version: 2.7.2
Python Path: ['/usr/local/www/freenasUI', '/usr/local/lib/python2.7/site-packages/setuptools-0.6c11-py2.7.egg', '/usr/local/lib/python2.7/site-packages/South-0.7.3-py2.7.egg', '/usr/local/lib/python2.7/site-packages/pyasn1-0.0.13b-py2.7.egg', '/usr/local/lib/python2.7/site-packages/pyasn1_modules-0.0.1a-py2.7.egg', '/usr/local/lib/python2.7/site-packages/flup-1.0.2-py2.7.egg', '/usr/local/lib/python2.7/site-packages/python_ldap-2.4.1-py2.7-freebsd-8.2-RELEASE-p5-amd64.egg', '/usr/local/lib/python27.zip', '/usr/local/lib/python2.7', '/usr/local/lib/python2.7/plat-freebsd8', '/usr/local/lib/python2.7/lib-tk', '/usr/local/lib/python2.7/lib-old', '/usr/local/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/site-packages', '/usr/local/www', '/usr/local/www', '/usr/local/www/freenasUI']
Server time: Sat, 16 Jun 2012 03:23:54 -0700
Traceback Switch to copy-and-paste view
/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py in get_response
resolver = urlresolvers.RegexURLResolver(r'^/', urlconf)
callback, callback_args, callback_kwargs = resolver.resolve(
request.path_info)
# Apply view middleware
for middleware_method in self._view_middleware:
response = middleware_method(request, callback, callback_args, callback_kwargs) ...
if response:
break
if response is None:
try:
response = callback(request, *callback_args, **callback_kwargs)
▶ Local vars
Variable Value
exceptions
u'<module 'django.core.exceptions' from '/usr/local/lib/python2.7/site-packages/django/core/exceptions.pyc'>'
callback_args
u'()'
receivers
u'[(<function _rollback_on_exception at 0x80349b488>, None)]'
middleware_method
u'<bound method RequireLoginMiddleware.process_view of <freenasUI.freeadmin.middleware.RequireLoginMiddleware object at 0x804d34a50>>'
self
u'<django.core.handlers.wsgi.WSGIHandler object at 0x804d2c850>'
settings
u'<django.conf.LazySettings object at 0x8021a5410>'
request
u'<WSGIRequest\nGET:<QueryDict: {}>,\nPOST:<QueryDict: {}>,\nCOOKIES:{'csrftoken': '7c59405bbc50176be86d7facf2deb958',\n 'mytreeSaveStateCookie': 'root%2C2%2C48%2C55%2C52%2C45%2C57%2C61%2C1%2C11',\n 'sessionid': '72bbcdb9897177c24f87d809fd10500d'},\nMETA:{'CONTENT_TYPE': 'application/x-www-form-urlencoded',\n 'DOCUMENT_ROOT': '/usr/local/www/data/',\n 'GATEWAY_INTERFACE': 'CGI/1.1',\n 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8',\n 'HTTP_ACCEPT_ENCODING': 'gzip, deflate',\n 'HTTP_ACCEPT_LANGUAGE': 'en-us,en;q=0.5',\n 'HTTP_CONNECTION': 'keep-alive',\n 'HTTP_COOKIE': 'mytreeSaveStateCookie=root%2C2%2C48%2C55%2C52%2C45%2C57%2C61%2C1%2C11; csrftoken=7c59405bbc50176be86d7facf2deb958; sessionid=72bbcdb9897177c24f87d809fd10500d',\n 'HTTP_HOST': '192.168.1.6',\n 'HTTP_REFERER': 'http://192.168.1.6/',\n 'HTTP_USER_AGENT': 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:12.0) Gecko/20100101 Firefox/12.0',\n 'HTTP_X_CSRFTOKEN': '7c59405bbc50176be86d7facf2deb958',\n 'HTTP_X_REQUESTED_WITH': 'XMLHttpRequest',\n 'PATH_INFO': u'/storage/auto-import/',\n 'PATH_TRANSLATED': '/usr/local/www/data//storage/auto-import/',\n 'QUERY_STRING': '',\n 'REDIRECT_STATUS': '200',\n 'REDIRECT_URI': '/mysite.fcgi/storage/auto-import/',\n 'REMOTE_ADDR': '192.168.1.5',\n 'REMOTE_PORT': '54891',\n 'REQUEST_METHOD': 'GET',\n 'REQUEST_URI': '/storage/auto-import/',\n 'SCRIPT_FILENAME': '/usr/local/www/data/mysite.fcgi',\n 'SCRIPT_NAME': u'',\n 'SERVER_ADDR': '192.168.1.6',\n 'SERVER_NAME': '192.168.1.6',\n 'SERVER_PORT': '80',\n 'SERVER_PROTOCOL': 'HTTP/1.1',\n 'SERVER_SOFTWARE': 'lighttpd/1.4.29',\n 'wsgi.errors': <flup.server.fcgi_base.TeeOutputStream object at 0x808a26390>,\n 'wsgi.input': <flup.server.fcgi_base.InputStream object at 0x806b95b50>,\n 'wsgi.multiprocess': False,\n 'wsgi.multithread': True,\n 'wsgi.run_once': False,\n 'wsgi.url_scheme': 'http',\n 'wsgi.version': (1, 0)}>'
callback
u'<function volautoimport at 0x8071268c0>'
resolver
u'<RegexURLResolver freenasUI.urls (None:None) ^/>'
urlresolvers
u'<module 'django.core.urlresolvers' from '/usr/local/lib/python2.7/site-packages/django/core/urlresolvers.pyc'>'
callback_kwargs
u'{}'
response
u'None'
urlconf
u''freenasUI.urls''
/usr/local/www/freenasUI/freeadmin/middleware.py in process_view
backend = get_backends()[0]
user.backend = "%s.%s" % (backend.__module__, backend.__class__.__name__)
login(request, user)
if request.path == settings.LOGIN_URL:
return None
if hasattr(view_func, '__is_public'):
return None
return login_required(view_func)(request,*view_args,**view_kwargs) ...
class LocaleMiddleware(object):
def process_request(self, request):
if request.method == 'GET' and 'lang' in request.GET:
language = request.GET['lang']
▶ Local vars
Variable Value
view_kwargs
u'{}'
view_args
u'()'
self
u'<freenasUI.freeadmin.middleware.RequireLoginMiddleware object at 0x804d34a50>'
request
view_func
/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py in _wrapped_view
that takes the user object and returns True if the user passes.
def decorator(view_func):
@wraps(view_func, assigned=available_attrs(view_func))
def _wrapped_view(request, *args, **kwargs):
if test_func(request.user):
return view_func(request, *args, **kwargs) ...
path = request.build_absolute_uri()
# If the login url is the same scheme and net location then just
# use the path as the "next" url.
login_scheme, login_netloc = urlparse.urlparse(login_url or
settings.LOGIN_URL)[:2]
current_scheme, current_netloc = urlparse.urlparse(path)[:2]
▶ Local vars
Variable Value
test_func
u'<function <lambda> at 0x804d4c668>'
login_url
u'None'
args
u'()'
request
kwargs
u'{}'
redirect_field_name
u''next''
view_func
/usr/local/www/freenasUI/storage/views.py in volautoimport
else:
if 'volume_disks' in request.POST:
disks = request.POST.getlist('volume_disks')
else:
disks = None
else:
form = forms.VolumeAutoImportForm() ...
disks = []
return render(request, 'storage/autoimport.html', {
'form': form,
'disks': disks
▶ Local vars
Variable Value
request
/usr/local/www/freenasUI/storage/forms.py in __init__
class VolumeAutoImportForm(forms.Form):
#volume_name = forms.CharField(max_length = 30, label = _('Volume name') )
volume_disks = forms.ChoiceField(choices=(), widget=forms.Select(attrs=attrs_dict), label = _('Member disk'))
def __init__(self, *args, **kwargs):
super(VolumeAutoImportForm, self).__init__(*args, **kwargs)
self.fields['volume_disks'].choices = self._populate_disk_choices() ...
def _populate_disk_choices(self):
diskchoices = dict()
used_disks = [notifier().identifier_to_device(i[0]) for i in models.Disk.objects.all().values_list('disk_identifier').distinct()]
▶ Local vars
Variable Value
self
u'<freenasUI.storage.forms.VolumeAutoImportForm object at 0x808a32190>'
args
u'()'
kwargs
u'{}'
/usr/local/www/freenasUI/storage/forms.py in _populate_disk_choices
# Grab partition list
# NOTE: This approach may fail if device nodes are not accessible.
vols = notifier().detect_volumes() ...
for vol in list(vols):
for vdev in vol['disks']['vdevs']:
for disk in vdev['disks']:
if filter(lambda x: x is not None and disk['name'].startswith(x), used_disks):
vols.remove(vol)
▶ Local vars
Variable Value
used_disks
u'[]'
self
diskchoices
u'{}'
RE_POOL_NAME = re.compile(r'pool: (?P<name>[a-z][a-z0-9_-]+)', re.I)
p1 = self.__pipeopen("zpool import")
res = p1.communicate()[0]
for pool in RE_POOL_NAME.findall(res):
# get status part of the pool
status = res.split('pool: %s\n' % pool)[1].split('pool:')[0] ...
roots = zfs.parse_status(pool, doc, status)
if roots[pool].status != 'UNAVAIL':
volumes.append({
'label': pool,
'type': 'zfs',
▶ Local vars
Variable Value
status
u'' id: 6855110416080880868\\n state: ONLINE\\naction: The pool can be imported using its name or numeric identifier.\\nconfig:\\n\\n\\tWD2TB ONLINE\\n\\t ada0p2 ONLINE\\n\\n ''
search
u'[]'
p1
u'<subprocess.Popen object at 0x808a1ed50>'
volumes
u'[{'cache': None,\n 'disks': {'id': '13',\n 'name': 'WD2TB',\n 'numVdevs': 1,\n 'status': 'ONLINE',\n 'vdevs': [{'disks': [{'id': '11',\n 'name': 'ada0p2',\n 'status': 'ONLINE'}],\n 'id': '12',\n 'name': 'stripe',\n 'numDisks': 1,\n 'status': 'ONLINE',\n 'type': 'stripe'}]},\n 'group_type': 'none',\n 'label': 'WD2TB',\n 'log': None,\n 'spare': None,\n 'type': 'zfs'}]'
extra
u'None'
res
u'' pool: WD2TB\\n id: 6855110416080880868\\n state: ONLINE\\naction: The pool can be imported using its name or numeric identifier.\\nconfig:\\n\\n\\tWD2TB ONLINE\\n\\t ada0p2 ONLINE\\n\\n pool: WD1.5TB\\n id: 13884691955919240954\\n state: ONLINE\\naction: The pool can be imported using its name or numeric identifier.\\nconfig:\\n\\n\\tWD1.5TB ONLINE\\n\\t ada1p2 ONLINE\\n''
self
u'<freenasUI.middleware.notifier.notifier instance at 0x807915518>'
geom
u''raid3''
roots
u'{'spare': None, 'cache': None, 'data': <middleware.zfs.Root object at 0x808a25210>, 'logs': None}'
RE_POOL_NAME
u'<_sre.SRE_Pattern object at 0x806c070c0>'
doc
u'<xmlDoc (None) object at 0x808a29758>'
pool
u''WD1''
Environment: Request Method: GET Request URL: http://192.168.1.6/storage/auto-import/ Django Version: 1.3.1 Python Version: 2.7.2 Installed Applications: ['django.contrib.auth', 'django.contrib.contenttypes', 'django.contrib.sessions', 'django.contrib.staticfiles', 'freeadmin', 'south', 'dojango', 'account', 'system', 'network', 'storage', 'sharing', 'services'] Installed Middleware: ('django.middleware.common.CommonMiddleware', 'django.contrib.sessions.middleware.SessionMiddleware', 'freenasUI.freeadmin.middleware.LocaleMiddleware', 'django.contrib.auth.middleware.AuthenticationMiddleware', 'freenasUI.freeadmin.middleware.RequireLoginMiddleware', 'django.middleware.csrf.CsrfViewMiddleware', 'dojango.middleware.DojoCollector') Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 105. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/freeadmin/middleware.py" in process_view 58. return login_required(view_func)(request,*view_args,**view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/storage/views.py" in volautoimport 203. form = forms.VolumeAutoImportForm() File "/usr/local/www/freenasUI/storage/forms.py" in __init__ 501. self.fields['volume_disks'].choices = self._populate_disk_choices() File "/usr/local/www/freenasUI/storage/forms.py" in _populate_disk_choices 510. vols = notifier().detect_volumes() File "/usr/local/www/freenasUI/middleware/notifier.py" in detect_volumes 1608. status = res.split('pool: %s\n' % pool)[1].split('pool:')[0] Exception Type: IndexError at /storage/auto-import/ Exception Value: list index out of range
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
csrftoken
sessionid
META
Variable Value
wsgi.multiprocess
False
HTTP_REFERER
REDIRECT_STATUS
'200'
SERVER_SOFTWARE
'lighttpd/1.4.29'
SCRIPT_NAME
u''
HTTP_X_CSRFTOKEN
REQUEST_METHOD
'GET'
PATH_INFO
SERVER_PROTOCOL
'HTTP/1.1'
QUERY_STRING
HTTP_USER_AGENT
HTTP_CONNECTION
'keep-alive'
HTTP_COOKIE
SERVER_NAME
'192.168.1.6'
REMOTE_PORT
'54891'
wsgi.url_scheme
'http'
PATH_TRANSLATED
SERVER_PORT
'80'
SERVER_ADDR
'192.168.1.6'
DOCUMENT_ROOT
'XMLHttpRequest'
SCRIPT_FILENAME
wsgi.input
HTTP_HOST
'192.168.1.6'
wsgi.multithread
True
REQUEST_URI
HTTP_ACCEPT
wsgi.version
(1, 0)
GATEWAY_INTERFACE
'CGI/1.1'
wsgi.run_once
False
wsgi.errors
REMOTE_ADDR
'192.168.1.5'
'en-us,en;q=0.5'
REDIRECT_URI
CONTENT_TYPE
'gzip, deflate'
Settings
Using settings module freenasUI.settings
Setting Value
YEAR_MONTH_FORMAT
'F Y'
USE_L10N
True
USE_THOUSAND_SEPARATOR
False
LANGUAGE_CODE
'en-us'
ROOT_URLCONF
'freenasUI.urls'
MANAGERS
(('iXsystems, Inc.', 'freenas@ixsystems.com'),)
DOJANGO_DATAGRID_ACCESS
('account', 'system', 'network', 'storage', 'sharing', 'services')
DEFAULT_CHARSET
'utf-8'
STATIC_ROOT
'/usr/local/www/freenasUI/static'
DOJANGO_DOJO_VERSION
'1.6.1'
MESSAGE_STORAGE
'django.contrib.messages.storage.user_messages.LegacyFallbackStorage'
DATABASE_HOST
IGNORABLE_404_STARTS
('/cgi-bin/', '/_vti_bin', '/_vti_inf')
SEND_BROKEN_LINK_EMAILS
False
URL_VALIDATOR_USER_AGENT
'Django/1.3.1 (http://www.djangoproject.com)'
STATICFILES_FINDERS
('django.contrib.staticfiles.finders.FileSystemFinder', 'django.contrib.staticfiles.finders.AppDirectoriesFinder')
SESSION_COOKIE_DOMAIN
None
SESSION_COOKIE_NAME
'sessionid'
COMMENTS_MODERATORS_GROUP
None
TIME_INPUT_FORMATS
('%H:%M:%S', '%H:%M', '%Y-%m-%dT%H:%M', '%Y-%m-%dT%H:%M:%S', 'T%H:%M:%S', 'T%H:%M')
DATABASES
{'default': {'ENGINE': 'django.db.backends.sqlite3', 'HOST': '', 'NAME': '/data/freenas-v1.db', 'OPTIONS': {}, 'PASSWORD': '********************', 'PORT': '', 'TEST_CHARSET': None, 'TEST_COLLATION': None, 'TEST_MIRROR': None, 'TEST_NAME': '/usr/local/www/freenasUI/test.db', 'TIME_ZONE': None, 'USER': ''}}
TEST_DATABASE_NAME
None
FILE_UPLOAD_PERMISSIONS
None
FILE_UPLOAD_HANDLERS
('django.core.files.uploadhandler.MemoryFileUploadHandler', 'django.core.files.uploadhandler.TemporaryFileUploadHandler')
DEFAULT_CONTENT_TYPE
'text/html'
APPEND_SLASH
True
FIRST_DAY_OF_WEEK
0
DATABASE_ROUTERS
DOJANGO_DOJO_PROFILE
'local_release'
STATICFILES_STORAGE
'django.contrib.staticfiles.storage.StaticFilesStorage'
CACHES
{'default': {'BACKEND': 'django.core.cache.backends.locmem.LocMemCache', 'LOCATION': ''}}
SERVER_EMAIL
'root@localhost'
SESSION_COOKIE_PATH
USE_X_FORWARDED_HOST
False
IGNORABLE_404_ENDS
('mail.pl', 'mailform.pl', 'mail.cgi', 'mailform.cgi', 'favicon.ico', '.php')
MIDDLEWARE_CLASSES
USE_I18N
True
THOUSAND_SEPARATOR
SECRET_KEY
LANGUAGE_COOKIE_NAME
'django_language'
FILE_UPLOAD_TEMP_DIR
'/var/tmp/firmware/'
TRANSACTIONS_MANAGED
False
LOGGING_CONFIG
'django.utils.log.dictConfig'
SESSION_COOKIE_AGE
1209600
TEMPLATE_LOADERS
('django.template.loaders.filesystem.Loader', 'django.template.loaders.app_directories.Loader')
TEMPLATE_DEBUG
False
AUTHENTICATION_BACKENDS
('django.contrib.auth.backends.ModelBackend',)
TEST_DATABASE_COLLATION
None
FORCE_SCRIPT_NAME
CACHE_BACKEND
'locmem://'
SESSION_COOKIE_SECURE
False
CSRF_COOKIE_DOMAIN
None
FILE_CHARSET
'utf-8'
DEBUG
False
SESSION_FILE_PATH
None
DEFAULT_FILE_STORAGE
'django.core.files.storage.FileSystemStorage'
INSTALLED_APPS
LANGUAGES
(('ar', 'Arabic'), ('az', 'Azerbaijani'), ('bg', 'Bulgarian'), ('bn', 'Bengali'), ('bs', 'Bosnian'), ('ca', 'Catalan'), ('cs', 'Czech'), ('cy', 'Welsh'), ('da', 'Danish'), ('de', 'German'), ('el', 'Greek'), ('en', 'English'), ('en-gb', 'British English'), ('es', 'Spanish'), ('es-ar', 'Argentinian Spanish'), ('es-mx', 'Mexican Spanish'), ('es-ni', 'Nicaraguan Spanish'), ('et', 'Estonian'), ('eu', 'Basque'), ('fa', 'Persian'), ('fi', 'Finnish'), ('fr', 'French'), ('fy-nl', 'Frisian'), ('ga', 'Irish'), ('gl', 'Galician'), ('he', 'Hebrew'), ('hi', 'Hindi'), ('hr', 'Croatian'), ('hu', 'Hungarian'), ('id', 'Indonesian'), ('is', 'Icelandic'), ('it', 'Italian'), ('ja', 'Japanese'), ('ka', 'Georgian'), ('km', 'Khmer'), ('kn', 'Kannada'), ('ko', 'Korean'), ('lt', 'Lithuanian'), ('lv', 'Latvian'), ('mk', 'Macedonian'), ('ml', 'Malayalam'), ('mn', 'Mongolian'), ('nl', 'Dutch'), ('no', 'Norwegian'), ('nb', 'Norwegian Bokmal'), ('nn', 'Norwegian Nynorsk'), ('pa', 'Punjabi'), ('pl', 'Polish'), ('pt', 'Portuguese'), ('pt-br', 'Brazilian Portuguese'), ('ro', 'Romanian'), ('ru', 'Russian'), ('sk', 'Slovak'), ('sl', 'Slovenian'), ('sq', 'Albanian'), ('sr', 'Serbian'), ('sr-latn', 'Serbian Latin'), ('sv', 'Swedish'), ('ta', 'Tamil'), ('te', 'Telugu'), ('th', 'Thai'), ('tr', 'Turkish'), ('uk', 'Ukrainian'), ('ur', 'Urdu'), ('vi', 'Vietnamese'), ('zh-cn', 'Simplified Chinese'), ('zh-tw', 'Traditional Chinese'))
DATABASE_ENGINE
BLACKLIST_NAV
('django.contrib.auth', 'django.contrib.contenttypes', 'django.contrib.sessions', 'django.contrib.staticfiles', 'south', 'dojango', 'freeadmin')
DATABASE_NAME
COMMENTS_FIRST_FEW
0
PREPEND_WWW
False
TEST_DATABASE_CHARSET
None
SESSION_COOKIE_HTTPONLY
False
DATABASE_PORT
DEBUG_PROPAGATE_EXCEPTIONS
False
MONTH_DAY_FORMAT
'F j'
LOGIN_URL
'/account/login/'
SESSION_EXPIRE_AT_BROWSER_CLOSE
False
TIME_FORMAT
'P'
DATE_INPUT_FORMATS
('%Y-%m-%d', '%m/%d/%Y', '%m/%d/%y', '%b %d %Y', '%b %d, %Y', '%d %b %Y', '%d %b, %Y', '%B %d %Y', '%B %d, %Y', '%d %B %Y', '%d %B, %Y', '%Y-%m-%dT%H:%M', '%Y-%m-%dT%H:%M:%S')
CSRF_COOKIE_NAME
'csrftoken'
EMAIL_HOST_PASSWORD
PASSWORD_RESET_TIMEOUT_DAYS
CACHE_MIDDLEWARE_ALIAS
'default'
SESSION_SAVE_EVERY_REQUEST
False
ADMIN_MEDIA_PREFIX
'/static/admin/'
NUMBER_GROUPING
0
SESSION_ENGINE
'django.contrib.sessions.backends.file'
CSRF_FAILURE_VIEW
'django.views.csrf.csrf_failure'
COMMENTS_SKETCHY_USERS_GROUP
None
LOGIN_REDIRECT_URL
LOGGING
{'disable_existing_loggers': False, 'handlers': {'mail_admins': {'class': 'django.utils.log.AdminEmailHandler', 'level': 'ERROR'}}, 'loggers': {'django.request': {'handlers': ['mail_admins'], 'level': 'ERROR', 'propagate': True}}, 'version': 1}
CACHE_MIDDLEWARE_KEY_PREFIX
LOCALE_PATHS
('/usr/local/www/freenasUI/locale',)
HERE
COMMENTS_ALLOW_PROFANITIES
False
LOGOUT_URL
'/account/logout/'
EMAIL_USE_TLS
False
TEMPLATE_DIRS
('/usr/local/www/freenasUI/templates',)
FIXTURE_DIRS
EMAIL_HOST
'localhost'
DATE_FORMAT
'N j, Y'
MEDIA_ROOT
'/usr/local/www/freenasUI/media'
ADMINS
FORMAT_MODULE_PATH
None
DEFAULT_FROM_EMAIL
'webmaster@localhost'
STATICFILES_DIRS
('/usr/local/www/freenasUI/media',)
MEDIA_URL
'/media/'
DATETIME_FORMAT
'N j, Y, P'
EMAIL_SUBJECT_PREFIX
'[Django] '
SITE_ID
DISALLOWED_USER_AGENTS
ALLOWED_INCLUDE_ROOTS
DECIMAL_SEPARATOR
SHORT_DATE_FORMAT
'm/d/Y'
DATABASE_USER
TEST_RUNNER
'django.test.simple.DjangoTestSuiteRunner'
TIME_ZONE
None
FILE_UPLOAD_MAX_MEMORY_SIZE
268435456
EMAIL_BACKEND
'django.core.mail.backends.smtp.EmailBackend'
DEFAULT_TABLESPACE
TEMPLATE_CONTEXT_PROCESSORS
('django.core.context_processors.request', 'django.contrib.auth.context_processors.auth', 'django.core.context_processors.i18n', 'django.core.context_processors.media', 'django.core.context_processors.static', 'dojango.context_processors.config')
DOJANGO_DOJO_DEBUG
True
SETTINGS_MODULE
'freenasUI.settings'
USE_ETAGS
False
LANGUAGES_BIDI
('he', 'ar', 'fa')
DEFAULT_INDEX_TABLESPACE
INTERNAL_IPS
STATIC_URL
'/media/'
EMAIL_PORT
25
SHORT_DATETIME_FORMAT
'm/d/Y P'
ABSOLUTE_URL_OVERRIDES
DATABASE_OPTIONS
CACHE_MIDDLEWARE_SECONDS
600
BANNED_IPS
TEMPLATE_STRING_IF_INVALID
DATETIME_INPUT_FORMATS
('%Y-%m-%d %H:%M:%S', '%Y-%m-%d %H:%M', '%Y-%m-%d', '%m/%d/%Y %H:%M:%S', '%m/%d/%Y %H:%M', '%m/%d/%Y', '%m/%d/%y %H:%M:%S', '%m/%d/%y %H:%M', '%m/%d/%y')
DATABASE_PASSWORD
ADMIN_FOR
PROFANITIES_LIST
EMAIL_HOST_USER
COMMENTS_BANNED_USERS_GROUP
None
You're seeing this error because you have DEBUG = True in your Django settings file. Change that to False, and Django will display a standard 500 page.
