I'm just beginning to try out using the FreeNAS API, and it appears that there's something special about getting the version.
The following is...
...is able to correctly return the "Advanced" data:
However, the following to get the "version" data...
...returns the login page for some reason:
Any ideas why I'm unable to get the system version using the FreeNAS API, but it instead sends a login page?
The following is...
import json
import requests
r = requests.get(
'http://192.168.1.140/api/v1.0/system/advanced/',
auth=('root', 'password'),
print r.text...is able to correctly return the "Advanced" data:
{"adv_advancedmode": false, "adv_anonstats": true, "adv_anonstats_token": "", "adv_autotune": false, "adv_consolemenu": true, "adv_consolemsg": false, "adv_consolescreensaver": false, "adv_debugkernel": false, "adv_motd": "Welcome to FreeNAS", "adv_powerdaemon": false, "adv_serialconsole": false, "adv_serialport": "0x2f8", "adv_serialspeed": "9600", "adv_swapondrive": 2, "adv_traceback": true, "adv_uploadcrash": true, "id": 1}However, the following to get the "version" data...
import json
import requests
r = requests.get(
'http://192.168.1.140/api/v1.0/system/version/',
print r.text...returns the login page for some reason:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html dir="ltr">
<head>
<title></title>
<meta http-equiv="Content-type" content="text/html; charset=utf-8" />
<style type="text/css">
@import "/dojango/dojo-media/release/1.9.2/dojo/resources/dojo.css?cache=";
@import "/dojango/dojo-media/release/1.9.2/dijit/themes/claro/claro.css?cache=";
@import "/static//lib/js/dgrid/css/skins/claro.css?cache=";
</style>
<script type="text/javascript">
var dojoConfig = {
has: {
"dojo-undef-api": true
isDebug: true,
parseOnLoad: true,
baseUrl: "/dojango/dojo-media/release/1.9.2/dojo",
async: true,
cacheBust: '',
packages: [
{name: "freeadmin", location: "/static/lib/js/freeadmin"},
{name: "dgrid", location: "/static/lib/js/dgrid"},
{name: "xstyle", location: "/static/lib/js/xstyle"},
{name: "put-selector", location: "/static/lib/js/put-selector"}
var CSRFToken = 'keMfqGe9bzkbqcyvOzma59pUw1k0Sfhw';
</script>
[...Much more HTML follows, including the following...]
<!-- THIS IS A LOGIN WEBPAGE -->
[...Then more HTML...]Any ideas why I'm unable to get the system version using the FreeNAS API, but it instead sends a login page?
