.freenas and .system show up in CIFS share.
S
scotch_tape
Guest
OP deleted original question...
bigphil
Do you mean they show up in under Storage/Volumes/<pool>/dataset in the GUI or is there actually a CIFS share? i.e. \\server\share ? Showing under Storage is normal. I'm on FreeNAS-9.2.1.4-BETA-8ca472a-x64 and I don't have them listed on my CIFS shares. What version are you running?
S
scotch_tape
Guest
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Ut at rutrum mauris, a bibendum nisl. Cum sociis natoque penatibus et magnis dis parturient montes, nascetur ridiculus mus. Duis gravida odio in eros porta porttitor. Proin ornare tincidunt mattis. Vestibulum vel nisl dignissim, consectetur felis sed, tristique augue. Nulla semper elit nec sem pulvinar, non convallis velit tincidunt. Nam egestas accumsan quam. Mauris efficitur nisi eget tellus suscipit, vitae posuere lacus suscipit.
bigphil
Do you have the option on the CIFS share to "Show hidden files" enabled? Its not the same as in something like Windows Explorer show hidden files option. If enabled, the option will show directories that begin with a "."
S
scotch_tape
Guest
bigphil
Its on the CIFS share settings itself, not the CIFS service settings.
S
scotch_tape
Guest
bigphil
Does this happen for all CIFS shares? Maybe you shared out the top folder in the pool and not a dataset below it?
You might have to cycle CIFS off, then on. But folders starting with a period won't show up unless you've overridden the setting. And there's several ways(not the least of which is the CIFS share settings).
bigphil
If you still have problems after following our advice, post your /etc/local/smb4.conf file and that will let us see all the setting you have applied and might help determine the issue.
bigphil
post your smb4.conf file or the contents of it in a post...like I said above. That should shed some light on what might be happening.
bigphil
This was the question I asked you in post #8! ;-) But to answer your question...you can create a CIFS share wherever you want. I'll say that typically you wouldn't share out the root of your pool, but as you found out, you certainly can. Just depends on your structure and what data your trying to access.
