Ihad install freeNAS 8.0.3, bot I can't see some tag on IE 8. But with Firefox Ican see.Those are Network/Global Config, Network/Summary. With IE 8 nothing is came up on those tab. Anyone has that problem and had solutaion?
Thanks for reply.
Did you mean freeNAS 8.0.2 or 8.2? Latest one was 8.0.3 p1.
I had try first on 8.0.2 already, then I move to 8.0.3 p1 the latest one. Both versions are the same problem with IE 8. I can work properly on Firefox.
