Been looking online and can't find an answer and this thread was as close if not the same issue. I hope someone here can help.
My supported adaptec 5805z is setup with a Raid-0 as a test. The OS can see & load the card but is not assigning a name to the logical or physical disks.
<NECVMWar VMware IDE CDR10 1.00> at scbus1 target 0 lun 0 (pass0,cd0)
<VMware Virtual disk 1.0> at scbus2 target 0 lun 0 (pass1,da0)
<WDC WD2000JD-00H 08.0> at scbus3 target 4 lun 0 (pass2) <--- ?
< ST3160023AS 3.43> at scbus3 target 5 lun 0 (pass3) <--- ?
< OCZ-AGILITY3 2.50> at scbus3 target 7 lun 0 (pass4) <--- ?
My end goal is to set this drive up as a raid6 and use iscsi to share out the resource and possibly have a backup drive to mirror it too.
If someone has a better solution please feel free to share.
I am running FreeNas and have tried versions 8 (last rel ver), 9.1, current release and daily alpha with Same result.
I am running in ESXI latest using my adaptec 5805z raid card in pass through mode.
I am building my VMDK's from setup using the iso's from freenas.
The same passthrough and raid combo works fine in a win 7 vm.
I know windows and am learning Linux so bare with me a bit but am pretty resourceful & with enough detail or pointers can work through most things. Google is my friend.. :)
Why do I not get an daX name for these drives?
Why do I not see a listing for the built up logical raid-0 drive?
Why is freenas not seeing anything (assumed its do to no name being issued)?
Can I force a name assignment?
Anything else I need do for FreeNas to see the drive(s)?
Anyone recommend using another distro to do iscsi easily from a hardware raid in the event this does not work (or I'm going about this wrong)?
Thanks in advance for any and all info. I can do all this in windows just want to make it work in Linux :)
-saridnour
Seattle
