SOLVED FreeNAS 9.3 ZFS Pool looks different than 9.2.1.9
C-N
Hi all,
Long time Freenas user & forum lurker here. I have a simple question (If you know the answer!) I just upgraded to 9.3 & my ZFS pool looks a little different than it did in 9.2.1.9. Everything is working fine but would just like someone to pass comment as to whether this is normal or not.
On 9.2** I had a named pool (volume01) & in that I had several datasets. In 9.3 I see volume01 as a pool & volume01 again as a dataset with my previously made datasets within. Is this normal?
Craig
C-N
Thanks for the reply & example very much appreciated.
