is there a way to update the sanzbd to 7.16 from the plugin 7.14 for sabnzbd is there a script
D denist Contributor Joined Jan 28, 2013 Messages 188 Sep 14, 2013 #1 is there a way to update the sanzbd to 7.16 from the plugin 7.14 for sabnzbd is there a script
D denist Contributor Joined Jan 28, 2013 Messages 188 Sep 14, 2013 #2 or csn i copy the files over to the pbi directory..... the last plugin for 8.3 had and update script... does 9.1 have this also denis
D denist Contributor Joined Jan 28, 2013 Messages 188 Sep 14, 2013 #3 also when the server shuts off.. do the plugins shut down.... as sometimes when it is down oad and then when it comes back the file is missing like its not saviong settings..
D denist Contributor Joined Jan 28, 2013 Messages 188 Sep 19, 2013 #5 I have reverted back to 8.3 freenas to keep using Joshua's plugins as I can update these with ease Until there is an easy way to do it with 9.1 plugins Denis Love freenas it east and giod
B BoogaBooga Cadet Joined Sep 7, 2013 Messages 8 Oct 12, 2013 #6 Yes.. This was driving me nuts too! I ended up creating a software jail and installed sabnzbd/cp/sb manually. GUI options do not add much anyway as far as these plugins go.
D denist Contributor Joined Jan 28, 2013 Messages 188 Oct 29, 2013 #7 Would you be kind enough on how you installed the 3 programs in a software jail Write up a quick tut from creating a software jail and then installing the software Denis
