It was taking forever to connect to my FreeNAS. It was never showing that there was an issue through SMART. I went by sound and replaced a drive via the GUI. It all seemed to go smoothly then I noticed that it was still degraded. I next ran zpool status -v. Here is the output:
This is on a FreeNAS 8.2 box with 5 - 2 terabyte drives in zfs raidz. The drive silvered properly from what I can tell. After replacing this drive I find that ada3 is the real problem.
What is my next course of action? I need to get the RAID back then take out drive ada3 and replace it with another I have here.
In a freebsg forum i tried this also:
Those guys over there said to just do a fresh install of 8.3 and import and repair it?
What can i do before having to do that?
Thanks in advance
[root@tank] /boot# zpool status -v pool: Tank state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://www.sun.com/msg/ZFS-8000-8A scrub: none requested config: NAME STATE READ WRITE CKSUM Tank DEGRADED 0 0 0 raidz1 DEGRADED 0 0 0 gptid/a9cdc49f-0c39-11e2-9903-001676d6a98b ONLINE 0 0 0 gptid/aa64809a-0c39-11e2-9903-001676d6a98b ONLINE 0 0 0 replacing DEGRADED 0 0 2 gptid/aafd2bc1-0c39-11e2-9903-001676d6a98b OFFLINE 0 0 0 gptid/03f81b29-5549-11e2-baec-001676d6a98b ONLINE 0 0 0 gptid/ab929715-0c39-11e2-9903-001676d6a98b ONLINE 0 0 0 gptid/ac251f8d-0c39-11e2-9903-001676d6a98b ONLINE 0 0 0 errors: Permanent errors have been detected in the following files:
[root@tank] /boot# zpool detach Tank gptid/aafd2bc1-0c39-11e2-9903-001676d6a98b cannot detach gptid/aafd2bc1-0c39-11e2-9903-001676d6a98b: no valid replicas
Thanks in advance
