I just installed version 8
FreeNAS-8.0-RELEASE-amd64 2011-May-02 and System information does not show how much RAM, anyone know how to turn that display on ?
Hmmm, you must be time travelling... FreeNAS 8.2 doesn't exist in this timeline yet... but FreeNAS 8.0 does and if I recall that is a known issue with 8.0 that has been fixed in the 8.01 betas.
I know where you are seeing the 8.2 now, it actually says FreeBSD if you look more closely. FreeNAS 8.0 is based on FreeBSD 8.2, and the memory was displayed incorrectly and has been fixed.
Thanks, the first gen of ver 8 i loaded, i could not do anything, so i went back to the latest ver 7 and found error in all the drives in the log told me to back up my data, that was under a 64bit zfs z2
Well if you get those errors resolved and want to try version 8 again, try the latest 8.01 beta, it handles importing volumes better. Good luck getting your errors fixed.
I installed the latest 8.0.1 Beta4 AMD64 version
Sorry, did not provide more info
Intel i3 2100T Sandy Bridge
Asus P8H67-M PRO/CSM
8GB of Corsair DDR3 1600 memory
OS on 4GB of Sandisk USB stick
6x 2TB of Seagate Green
Intel Pro 1000 Nic
Plextor DVD writer
Antec Nine hundred case
Seasonic 520 Watts Gold plus PSU
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
