FreeNAS 11 Webserver Issue
Ahjohng
After upgrading from 9.2somthing, the first hit onto this webserver was fine. However, hours later, when I tried to hit it again, it showed the attached. I am running Edge on Windows 10. Is this related to some cookie thing? Please help and please fix this bug.
I've personally never had edge function properly on the FreeNAS GUI i always use chrome.
Edge works fine, as does Firefox.
Clear the browser cache for your server. Start with CTRL+F5.
The problem is that the browser cache was full of stuff for the old version. It's not completely clear why this happens, but a few bugs related to that have been squashed over the years. Hopefully, the new GUI will behave properly.
Unfortunately that did not work for me any other idea's
It depends on what the problem is, exactly...
my edge loads exactly the same as shown in Ahjohng's screen shot I've tried it in in private mode and obviously tried your initial suggestion. works perfectly in chrome, does not work in internet explorer either.
edit:maybe this will help screenshot from windows 10 edge browser
Before or after you login?
just added a screen shot, it's after login
