FreeNAS 11.3-U4.1 fails to join domain after update
andrewjones216
Hi all,
I am unable to join our domain after upgrading our Freenas to the latest stable release (11.3-U4.1). The interface times out when trying to save the settings.
I've got another FreeNAS box on the same version with the same AD settings connected ok. The output below suggests it has some old info cached somewhere, maybe?
Domain has been obfuscated to 'our.domain'
Workgroup parameter has been obfuscated to 'workgroup'
I've tried:
root@CNAS05:~ # service winbindd onestart
winbindd already running?  (pid=5846).
root@CNAS05:~ # ping cwm-dc-01
PING cwm-dc-01.our.domain (xxx.xxx.11.51): 56 data bytes
64 bytes from xxx.xxx.11.51: icmp_seq=0 ttl=128 time=0.779 ms
64 bytes from xxx.xxx.11.51: icmp_seq=1 ttl=128 time=0.839 ms
64 bytes from xxx.xxx.11.51: icmp_seq=2 ttl=128 time=0.727 ms
root@CNAS05:~ # dig our.domain
; <<>> DiG 9.14.6 <<>> our.domain
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 32686
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4000
;; QUESTION SECTION:
;our.domain.                  IN      A
;; ANSWER SECTION:
our.domain.           600     IN      A       xxx.xxx.10.53
our.domain.           600     IN      A       xxx.xxx.10.163
our.domain.           600     IN      A       xxx.xxx.11.52
our.domain.           600     IN      A       xxx.xxx.11.51
;; Query time: 1 msec
;; SERVER: xxx.xxx.11.51#53(xxx.xxx.11.51)
;; WHEN: Thu Aug 13 18:29:41 BST 2020
;; MSG SIZE  rcvd: 105
root@CNAS05:~ # host -t srv _ldap._tcp.our.domain
_ldap._tcp.our.domain has SRV record 0 100 389 CWM-DC-01.our.domain.
_ldap._tcp.our.domain has SRV record 0 100 389 cwm-dc-02.our.domain.
_ldap._tcp.our.domain has SRV record 0 100 389 cwm-dc-01.our.domain.
_ldap._tcp.our.domain has SRV record 0 100 389 cdc01.our.domain.
_ldap._tcp.our.domain has SRV record 0 100 389 CWM-DC-02.our.domain.
; <<>> DiG 9.14.6 <<>> pdc.our.domain
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 32981
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;pdc.our.domain.              IN      A
;; AUTHORITY SECTION:
our.domain.           3600    IN      SOA     cwm-dc-01.our.domain. hostmaster.our.domain. 182354 900 600 86400 3600
;; WHEN: Thu Aug 13 18:30:21 BST 2020
;; MSG SIZE  rcvd: 114
root@CNAS05:~ # net -k -d 5 ads testjoin
INFO: Current debug levels:
  all: 5
  tdb: 5
  printdrivers: 5
  lanman: 5
  smb: 5
  rpc_parse: 5
  rpc_srv: 5
  rpc_cli: 5
  passdb: 5
  sam: 5
  auth: 5
  winbind: 5
  vfs: 5
  idmap: 5
  quota: 5
  acls: 5
  locking: 5
  msdfs: 5
  dmapi: 5
  registry: 5
  scavenger: 5
  dns: 5
  ldb: 5
  tevent: 5
  auth_audit: 5
  auth_json_audit: 5
  kerberos: 5
  drs_repl: 5
  smb2: 5
  smb2_credits: 5
  dsdb_audit: 5
  dsdb_json_audit: 5
  dsdb_password_audit: 5
  dsdb_password_json_audit: 5
  dsdb_transaction_audit: 5
  dsdb_transaction_json_audit: 5
  dsdb_group_audit: 5
  dsdb_group_json_audit: 5
lp_load_ex: refreshing parameters
Initialising global parameters
  all: 5
  tdb: 5
  printdrivers: 5
  lanman: 5
  smb: 5
  rpc_parse: 5
  rpc_srv: 5
  rpc_cli: 5
  passdb: 5
  sam: 5
  auth: 5
  winbind: 5
  vfs: 5
  idmap: 5
  quota: 5
  acls: 5
  locking: 5
  msdfs: 5
  dmapi: 5
  registry: 5
  scavenger: 5
  dns: 5
  ldb: 5
  tevent: 5
  auth_audit: 5
  auth_json_audit: 5
  kerberos: 5
  drs_repl: 5
  smb2: 5
  smb2_credits: 5
  dsdb_audit: 5
  dsdb_json_audit: 5
  dsdb_group_audit: 5
Processing section "[global]"
doing parameter dns proxy = No
doing parameter aio max threads = 2
doing parameter max log size = 51200
doing parameter allocation roundup size = 0
doing parameter load printers = No
doing parameter printing = bsd
doing parameter disable spoolss = Yes
doing parameter dos filemode = Yes
doing parameter kernel change notify = No
doing parameter directory name cache size = 0
doing parameter nsupdate command = /usr/local/bin/samba-nsupdate -g
doing parameter unix charset = UTF-8
doing parameter log level = 3
doing parameter obey pam restrictions = False
doing parameter enable web service discovery = True
doing parameter logging = file
doing parameter server min protocol = SMB2_02
doing parameter unix extensions = No
doing parameter map to guest = Bad User
doing parameter server string = CNAS05 FreeNAS Storage Server
doing parameter bind interfaces only = Yes
doing parameter netbios name = CNAS05
doing parameter netbios aliases =
doing parameter server role = standalone
doing parameter workgroup = workgroup
doing parameter idmap config *: backend = tdb
doing parameter idmap config *: range = 90000001-100000000
doing parameter include = /usr/local/etc/smb4_share.conf
pm_process() returned Yes
Registering messaging pointer for type 2 - private_data=0x0
Registering messaging pointer for type 9 - private_data=0x0
Registered MSG_REQ_POOL_USAGE
Registering messaging pointer for type 11 - private_data=0x0
Registering messaging pointer for type 12 - private_data=0x0
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Registering messaging pointer for type 1 - private_data=0x0
Registering messaging pointer for type 5 - private_data=0x0
Registering messaging pointer for type 51 - private_data=0x0
Freeing parametrics:
  all: 5
  tdb: 5
  printdrivers: 5
  lanman: 5
  smb: 5
  rpc_parse: 5
  rpc_srv: 5
  rpc_cli: 5
  passdb: 5
  sam: 5
  auth: 5
  winbind: 5
  vfs: 5
  idmap: 5
  quota: 5
  acls: 5
  locking: 5
  msdfs: 5
  dmapi: 5
  registry: 5
  scavenger: 5
  dns: 5
  ldb: 5
  tevent: 5
  auth_audit: 5
  auth_json_audit: 5
  kerberos: 5
  drs_repl: 5
  smb2: 5
  smb2_credits: 5
  dsdb_audit: 5
  dsdb_json_audit: 5
  dsdb_group_audit: 5
Netbios name list:-
my_netbios_names[0]="CNAS05"
added interface ix0 ip=xxx.16.0.2 bcast=xxx.16.0.7 netmask=255.255.255.248
added interface igb0 ip=xxx.xxx.10.77 bcast=xxx.xxx.10.255 netmask=255.255.255.0
Opening cache file at /var/run/samba4/gencache.tdb
sitename_fetch: No stored sitename for realm ''
ads_dc_name: domain=workgroup
saf_fetch: failed to find server for "workgroup" domain
get_dc_list: preferred server list: ", *"
no entry for workgroup#1C found.
resolve_lmhosts: Attempting lmhosts lookup for name workgroup<0x1c>
startlmhosts: Can't open lmhosts file /usr/local/etc/lmhosts. Error was No such file or directory
resolve_wins: WINS server resolution selected and no WINS servers listed.
resolve_hosts: not appropriate for name type <0x1c>
name_resolve_bcast: Attempting broadcast lookup for name workgroup<0x1c>
get_dc_list: no servers found
ads_find_dc: name resolution for realm '' (domain 'workgroup') failed: NT_STATUS_NO_LOGON_SERVERS
Could not look up dc's for domain workgroup
ads_connect: No logon servers are currently available to service the logon request.
Join to domain is not valid: No logon servers are currently available to service the logon request.
return code = -1
root@CNAS05:~ # wbinfo -t
checking the trust secret for domain CNM via RPC calls failed
wbcCheckTrustCredentials(CNM): error code was NT_STATUS_NO_SUCH_DOMAIN (0xc00000df)
failed to call wbcCheckTrustCredentials: WBC_ERR_AUTH_ERROR
Could not check secret
root@CNAS05:~ # wbinfo -m
BUILTIN
CNAS05
Web GUI shows this:
Any help would be much appreciated.
Thanks
Andrew
andrewjones216
Update:
When trying to save in the Web GUI, it takes it's time but eventually displays the error:
Failed to validate bind credentials: kinit for domain [our.domain] with password failed: kinit: krb5_get_init_creds: unable to reach any KDC in realm our.domain
Update 2:
Tried changing the SASL wrapping as per this bug report https://jira.ixsystems.com/browse/NAS-104916?jql=text ~ "Server 2019"
  • With SEAL selected: Failed to validate bind credentials: kinit for domain [our.domain] with password failed: kinit: krb5_get_init_creds: unable to reach any KDC in realm our.domain
  • With PLAIN selected: Failed to validate bind credentials: kinit for domain [our.domain] with password failed: kinit: krb5_get_init_creds: unable to reach any KDC in realm our.domain
Going to try any and all the bug fixes/ reports I have found on the jira platform later on today, any input would be appreciated.
andrewjones216
Update
Have tried some of the bug fixes from Jira:
https://jira.ixsystems.com/browse/NAS-107107?jql=project = NAS
https://github.com/freenas/freenas/pull/5396
  • Backed up config including keys
  • Recorded the output of "cat /etc/krb5.conf" and take copy via winscp - empty no point!
  • Recorded the output of "cat /etc/krb5.keytab" and take copy via winscp - file doesn't exist
  • Backed up secrets.tdb
- Delete any keytabs; No keytabs available to delete
- Delete any realms; No realms available to delete
- rename "/var/db/system/samba4/private/secrets.tdb" to "/var/db/system/samba4/private/secrets.tdb.bak.{int(ts)}"; renamed secrets.tdb from "/var/db/system/samba4/private/secrets.tdb" to "/var/db/system/samba4/private/secrets.tdb.bak"
- flush samba cache; flushed samba cache "net cache flush"
- restarted winbindd services "service winbindd restart"
- Try joining domain again; Tried to join domain: "Failed to validate bind credentials: kinit for domain [domain_name] with password failed: kinit: krb5_get_init_creds: unable to reach any KDC in realm domain_name"
- The process did create a new secrets.tdb file
- Ran debug and net -k d10 ads testjoin; failed.
- Checked DC time against CNAS05 time: DC time: 19:02 27/08/2020 CNAS05 time: Thu Aug 27 19:02:33 BST 2020
I have the debug and testjoin output but it's very much the same as above. Both appear to try and use the workgroup name to call the domain.
Any thoughts?
anodos
Sambassador
When you say "times out when saving", as in clicking "OK" hits a middleware timeout? The AD update performs a quick validation of credentials via `kinit` before handing off the actual domain join to a backgrounded job. If it times out at this point, then the problem is probably kerberos-related. Check lookups of your kerberos-related SRV records. If you enable verbose logging, you should see more output in /var/log/middlewared.log about the state of things. Preferred security settings are SSL: OFF, sasl_wrapping: SEAL.
andrewjones216
Hi anodos,
I’ve broken my reply to you up in to sections below;
When clicking 'Save' (see image below) the spinning circle ‘Please wait’ comes up for about 5 minutes before displaying the message "Failed to validate bind credentials: kinit for domain [our.domain] with password failed: kinit: krb5_get_init_creds: unable to reach any KDC in realm our.domain" below the password text box.
64 bytes from xxx. xxx.11.51: icmp_seq=0 ttl=128 time=0.759 ms
64 bytes from xxx. xxx.11.51: icmp_seq=1 ttl=128 time=0.775 ms
64 bytes from xxx. xxx.11.51: icmp_seq=2 ttl=128 time=0.582 ms
root@CNAS05:~ # ping cwm-dc-02
PING cwm-dc-02.out.domain (xxx.xxx.11.52): 56 data bytes
64 bytes from xxx. xxx.11.52: icmp_seq=0 ttl=128 time=0.558 ms
64 bytes from xxx. xxx.11.52: icmp_seq=1 ttl=128 time=0.437 ms
64 bytes from xxx. xxx.11.52: icmp_seq=2 ttl=128 time=0.458 ms
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 39980
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
;our.domain. IN A
;; ANSWER SECTION:
;; WHEN: Wed Sep 02 08:29:04 BST 2020
;; MSG SIZE rcvd: 89
root@CNAS05:~ # dig pdc.our.domain
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 57463
our.domain. 3600 IN SOA cwm-dc-01.our.domain. hostmaster.our.domain. 182805 900 600 86400 3600
;; WHEN: Wed Sep 02 08:31:03 BST 2020
--- Verbose logging ticked, SSL OFF and sasl_wrapping set to SEAL (although I did try SIGN as well). Output from middlewared.log from the time I started below.
[2020/09/01 17:21:21] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/01 17:21:42] (WARNING) UpdateService.get_trains():297 - Failed to retrieve trains redirection
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
    raise err
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 61] Connection refused
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
    chunked=chunked,
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 376, in _make_request
    self._validate_conn(conn)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 994, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 334, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
    self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x860b67b10>: Failed to establish a new connection: [Errno 61] Connection refused
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
    method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x860b67b10>: Failed to establish a new connection: [Errno 61] Connection refused'))
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 295, in get_trains
    redir_trains = self._get_redir_trains()
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 277, in _get_redir_trains
    timeout=5,
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.7/site-packages/raven/breadcrumbs.py", line 341, in send
    resp = real_send(self, request, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x860b67b10>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/01 17:21:42] (DEBUG) freenasOS.Configuration.TryGetNetworkFile():606 - TryGetNetworkFile(['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt'])
[2020/09/01 17:21:42] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update.ixsystems.com:443
[2020/09/01 17:21:47] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x83ed1df10>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/01 17:21:47] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/01 17:21:57] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x87c0eb8d0>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/01 17:21:57] (ERROR) freenasOS.Configuration.TryGetNetworkFile():709 - Unable to load ['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt']: Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt
[2020/09/01 17:21:57] (WARNING) application.call_method():168 - Exception while calling update.check_available(*[])
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
    io_thread=False)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1098, in _call
    return await run_method(methodobj, *args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1022, in _run_in_conn_threadpool
    return await self.run_in_executor(self.__ws_threadpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1010, in run_in_executor
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 422, in check_available
    trains = self.middleware.call_sync('update.get_trains')
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1157, in call_sync
    io_thread=True, job_on_progress_cb=job_on_progress_cb,
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1180, in run_coroutine
    return fut.result()
  File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 428, in result
    return self.__get_result()
  File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 384, in __get_result
    raise self._exception
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 302, in get_trains
    for name, descr in (conf.AvailableTrains() or {}).items():
  File "/usr/local/lib/freenasOS/Configuration.py", line 987, in AvailableTrains
    fileref = self.TryGetNetworkFile(file=TRAIN_FILE, reason="FetchTrains")
  File "/usr/local/lib/freenasOS/Configuration.py", line 710, in TryGetNetworkFile
    raise url_exc
freenasOS.Exceptions.UpdateNetworkConnectionException: Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt
[2020/09/01 17:21:57] (DEBUG) application.__crash_reporting():173 - [Crash Reporting] is disabled using sentinel file.
[2020/09/01 17:36:52] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/01 17:37:03] (WARNING) UpdateService.get_trains():297 - Failed to retrieve trains redirection
    raise err
    sock.connect(sa)
    chunked=chunked,
    conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x87befa0d0>: Failed to establish a new connection: [Errno 61] Connection refused
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x87befa0d0>: Failed to establish a new connection: [Errno 61] Connection refused'))
    timeout=5,
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x87befa0d0>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/01 17:37:03] (DEBUG) freenasOS.Configuration.TryGetNetworkFile():606 - TryGetNetworkFile(['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt'])
[2020/09/01 17:37:03] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update.ixsystems.com:443
[2020/09/01 17:37:03] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x87bffb9d0>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/01 17:37:03] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/01 17:37:07] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x87bffb410>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/01 17:37:07] (ERROR) freenasOS.Configuration.TryGetNetworkFile():709 - Unable to load ['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt']: Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt
[2020/09/01 17:37:07] (WARNING) application.call_method():168 - Exception while calling update.check_available(*[])
    io_thread=False)
    return fut.result()
    raise url_exc
[2020/09/01 17:37:07] (DEBUG) application.__crash_reporting():173 - [Crash Reporting] is disabled using sentinel file.
[2020/09/01 18:02:45] (ERROR) iocage.callback():63 - Failed to update git repository: fatal: Unable to create '/mnt/AppData1/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git/.git/index.lock': Read-only file system
[2020/09/01 18:02:45] (DEBUG) git.repo.base._clone():938 - Cmd(['git', 'clone', '-v', 'https://github.com/freenas/iocage-ix-plugins.git', '/mnt/AppData1/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git'])'s unused stdout:
[2020/09/01 18:02:45] (ERROR) middlewared.job.run():361 - Job <bound method accepts.<locals>.wrap.<locals>.nf of <middlewared.plugins.jail.PluginService object at 0x82c860350>> failed
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 1578, in _clone_repo
    for k in ['http_proxy', 'https_proxy'] if
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_exec.py", line 268, in __init__
    self.output = list(silent)
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_exec.py", line 260, in exec_jail
    list(stderr_queue)
iocage_lib.ioc_exceptions.CommandFailed: [b"fatal: Unable to create '/mnt/AppData1/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git/.git/index.lock': Read-only file system\n", b'', b'', b'', b'', b'']
  File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
    await self.future
  File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 387, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *([self] + args))
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 409, in available
    plugins_versions_data = IOCPlugin(branch=branch, git_repository=plugin_repository).fetch_plugin_versions()
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 266, in fetch_plugin_versions
    self.pull_clone_git_repo()
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 137, in pull_clone_git_repo
    depth, self.callback
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 1631, in _clone_repo
    k: v for k, v in kwargs.items() if v
  File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 988, in clone_from
    return cls._clone(git, url, to_path, GitCmdObjectDB, progress, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 939, in _clone
    finalize_process(proc, stderr=stderr)
  File "/usr/local/lib/python3.7/site-packages/git/util.py", line 333, in finalize_process
    proc.wait(**kwargs)
  File "/usr/local/lib/python3.7/site-packages/git/cmd.py", line 415, in wait
    raise GitCommandError(self.args, status, errstr)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v https://github.com/freenas/iocage-ix-plugins.git /mnt/AppData1/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git
  stderr: 'fatal: destination path '/mnt/AppData1/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git' already exists and is not an empty directory.
[2020/09/01 18:02:46] (DEBUG) git.repo.base._clone():938 - Cmd(['git', 'clone', '-v', 'https://github.com/ix-plugin-hub/iocage-plugin-index.git', '/mnt/AppData1/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git'])'s unused stdout:
[2020/09/01 18:02:46] (ERROR) middlewared.job.run():361 - Job <bound method accepts.<locals>.wrap.<locals>.nf of <middlewared.plugins.jail.PluginService object at 0x82c860350>> failed
    list(stderr_queue)
iocage_lib.ioc_exceptions.CommandFailed: [b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'', b'']
    await self.future
    proc.wait(**kwargs)
  cmdline: git clone -v https://github.com/ix-plugin-hub/iocage-plugin-index.git /mnt/AppData1/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git
  stderr: 'fatal: destination path '/mnt/AppData1/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git' already exists and is not an empty directory.
anodos
Sambassador
Once again we're unable to kinit because we can't find a KDC through DNS. Checking for LDAP SRV records won't help in this case (host -t srv _ldap._tcp.our.domain)
class SRV(enum.Enum):
    DOMAINCONTROLLER = '_ldap._tcp.dc._msdcs.'
    FORESTGLOBALCATALOG = '_ldap._tcp.gc._msdcs.'
    GLOBALCATALOG = '_gc._tcp.'
    KERBEROS = '_kerberos._tcp.'
    KERBEROSDOMAINCONTROLLER = '_kerberos._tcp.dc._msdcs.'
    KPASSWD = '_kpasswd._tcp.'
    LDAP = '_ldap._tcp.'
    PDC = '_ldap._tcp.pdc._msdcs.'
If you can look up a KDC through DNS successfully, then remove any kerberos realms you may have added in our GUI and start over with the AD form.
andrewjones216
Hi anodos,
root@CNAS05:~ # nslookup cwm-dc-01
Server: xxx.xxx.11.51
Address: xxx.xxx.11.51#53
root@CNAS05:~ # nslookup cwm-dc-02
Address: xxx.xxx.11.52
root@CNAS05:~ # host -t srv _ldap._tcp.dc._msdcs.our.domain
_ldap._tcp.dc._msdcs.our.domain has SRV record 0 100 389 cwm-dc-02.our.domain.
_ldap._tcp.dc._msdcs.our.domain has SRV record 0 100 389 cdc01.our.domain.
_ldap._tcp.dc._msdcs.our.domain has SRV record 0 100 389 CWM-DC-02.our.domain.
_ldap._tcp.dc._msdcs.our.domain has SRV record 0 100 389 CWM-DC-01.our.domain.
_ldap._tcp.dc._msdcs.our.domain has SRV record 0 100 389 cwm-dc-01.our.domain.
root@CNAS05:~ # host -t srv _ldap._tcp.gc._msdcs.our.domain
_ldap._tcp.gc._msdcs.our.domain has SRV record 0 100 3268 CWM-DC-02.our.domain.
_ldap._tcp.gc._msdcs.our.domain has SRV record 0 100 3268 CWM-DC-01.our.domain.
_ldap._tcp.gc._msdcs.our.domain has SRV record 0 100 3268 cdc01.our.domain.
_ldap._tcp.gc._msdcs.our.domain has SRV record 0 100 3268 cwm-dc-02.our.domain.
_ldap._tcp.gc._msdcs.our.domain has SRV record 0 100 3268 cwm-dc-01.our.domain.
root@CNAS05:~ # host -t srv _gc._tcp.our.domain
_gc._tcp.our.domain has SRV record 0 100 3268 cwm-dc-02.our.domain.
_gc._tcp.our.domain has SRV record 0 100 3268 cwm-dc-01.our.domain.
_gc._tcp.our.domain has SRV record 0 100 3268 CWM-DC-01.our.domain.
_gc._tcp.our.domain has SRV record 0 100 3268 CWM-DC-02.our.domain.
_gc._tcp.our.domain has SRV record 0 100 3268 cdc01.our.domain.
root@CNAS05:~ # host -t srv _kerberos._tcp.our.domain
_kerberos._tcp.our.domain has SRV record 0 100 88 cdc01.our.domain.
_kerberos._tcp.our.domain has SRV record 0 100 88 CWM-DC-01.our.domain.
_kerberos._tcp.our.domain has SRV record 0 100 88 CWM-DC-02.our.domain.
_kerberos._tcp.our.domain has SRV record 0 100 88 cwm-dc-01.our.domain.
_kerberos._tcp.our.domain has SRV record 0 100 88 cwm-dc-02.our.domain.
root@CNAS05:~ # host -t srv _kerberos._tcp.dc._msdcs.our.domain
_kerberos._tcp.dc._msdcs.our.domain has SRV record 0 100 88 cwm-dc-02.our.domain.
_kerberos._tcp.dc._msdcs.our.domain has SRV record 0 100 88 CWM-DC-02.our.domain.
_kerberos._tcp.dc._msdcs.our.domain has SRV record 0 100 88 CWM-DC-01.our.domain.
_kerberos._tcp.dc._msdcs.our.domain has SRV record 0 100 88 cwm-dc-01.our.domain.
_kerberos._tcp.dc._msdcs.our.domain has SRV record 0 100 88 cdc01.our.domain.
root@CNAS05:~ # host -t srv _kpasswd._tcp.our.domain
_kpasswd._tcp.our.domain has SRV record 0 100 464 cwm-dc-02.our.domain.
_kpasswd._tcp.our.domain has SRV record 0 100 464 CWM-DC-02.our.domain.
_kpasswd._tcp.our.domain has SRV record 0 100 464 cwm-dc-01.our.domain.
_kpasswd._tcp.our.domain has SRV record 0 100 464 CWM-DC-01.our.domain.
_kpasswd._tcp.our.domain has SRV record 0 100 464 cdc01.our.domain.
root@CNAS05:~ # host -t srv _ldap._tcp.pdc._msdcs.our.domain
_ldap._tcp.pdc._msdcs.our.domain has SRV record 0 100 389 CWM-DC-02.our.domain.
Can successfully lookup KDC through DNS. No Kerberos Realm to delete in the GUI:
Tried to add to the domain and failed with the same error as before.
Cheers
Andrew
andrewjones216
Hi all,
Any idea what's happening here? Could really do with resolving this one!
Cheers
Andrew
anodos
Sambassador
Is this Microsoft AD or Samba AD?
You could bypass the DNS lookup options in the base kerberos and see if that gets past your validation issues. You can achieve this by manually generating a realm entry for your realm (make sure you put in realm name in ALL CAPS -- kerberos is case-sensitive for realm name and convention is to use upper-case), then hard-code the fqdn for one or more of your DCs for each of the kerberos-related servers.
Then add appropriate auxiliary parameters to disable DNS lookups for kerberos info:
              dns_lookup_kdc = boolean
               Use DNS SRV records to lookup KDC services loca-
               tion.
              dns_lookup_realm = boolean
               Use DNS TXT records to lookup domain    to realm map-
               pings.
^^^ these are some supported libdefaults parameters for kerberos config. See manpage here: https://www.freebsd.org/cgi/man.cgi...FreeBSD+12.1-RELEASE&arch=default&format=html
These steps should not be required. Also, please revert any changes made to OS files to try to troubleshoot the issue.
andrewjones216
Hi anodos,
Microsoft AD (Server 2019 - 2016 AD)
Below are screenshots of the Kerberos Realm and Aux Parameters set, also the error generated by trying to connect to the domain.
What I don't understand is that we have another box with the same version of FreeNAS in the same subnet connected to AD fine.
I've also taken the middlewared.log from when I started entering these settings:
[2020/09/21 17:40:05] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/21 17:40:05] (WARNING) UpdateService.get_trains():297 - Failed to retrieve trains redirection
    raise err
    sock.connect(sa)
    chunked=chunked,
    conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x8b0b5e750>: Failed to establish a new connection: [Errno 61] Connection refused
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b0b5e750>: Failed to establish a new connection: [Errno 61] Connection refused'))
    timeout=5,
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b0b5e750>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:40:05] (DEBUG) freenasOS.Configuration.TryGetNetworkFile():606 - TryGetNetworkFile(['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt'])
[2020/09/21 17:40:05] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update.ixsystems.com:443
[2020/09/21 17:40:06] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b1a43410>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:40:06] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/21 17:40:06] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b1a4bad0>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:40:06] (ERROR) freenasOS.Configuration.TryGetNetworkFile():709 - Unable to load ['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt']: Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt
[2020/09/21 17:40:06] (WARNING) application.call_method():168 - Exception while calling update.check_available(*[])
    io_thread=False)
    return fut.result()
    raise url_exc
[2020/09/21 17:40:06] (DEBUG) application.__crash_reporting():173 - [Crash Reporting] is disabled using sentinel file.
[2020/09/21 17:42:19] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/21 17:42:19] (WARNING) UpdateService.get_trains():297 - Failed to retrieve trains redirection
    raise err
    sock.connect(sa)
    chunked=chunked,
    conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x8b1a9a410>: Failed to establish a new connection: [Errno 61] Connection refused
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b1a9a410>: Failed to establish a new connection: [Errno 61] Connection refused'))
    timeout=5,
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b1a9a410>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:42:19] (DEBUG) freenasOS.Configuration.TryGetNetworkFile():606 - TryGetNetworkFile(['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt'])
[2020/09/21 17:42:19] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update.ixsystems.com:443
[2020/09/21 17:42:19] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b1a00d90>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:42:19] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b1a821d0>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:42:19] (ERROR) freenasOS.Configuration.TryGetNetworkFile():709 - Unable to load ['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt']: Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt
[2020/09/21 17:42:19] (WARNING) application.call_method():168 - Exception while calling update.check_available(*[])
    io_thread=False)
    return fut.result()
    raise url_exc
[2020/09/21 17:42:19] (DEBUG) application.__crash_reporting():173 - [Crash Reporting] is disabled using sentinel file.
[2020/09/21 17:45:04] (DEBUG) ServiceService._simplecmd():286 - Calling: restart(cron)
[2020/09/21 17:45:04] (DEBUG) EtcService.generate():275 - No new changes for /etc/crontab
[2020/09/21 17:45:39] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/09/21 17:45:39] (WARNING) UpdateService.get_trains():297 - Failed to retrieve trains redirection
    raise err
    sock.connect(sa)
    chunked=chunked,
    conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x8b0bd0450>: Failed to establish a new connection: [Errno 61] Connection refused
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b0bd0450>: Failed to establish a new connection: [Errno 61] Connection refused'))
    timeout=5,
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b0bd0450>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:45:39] (DEBUG) freenasOS.Configuration.TryGetNetworkFile():606 - TryGetNetworkFile(['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt'])
[2020/09/21 17:45:39] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update.ixsystems.com:443
[2020/09/21 17:45:39] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b0be6810>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:45:39] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x8b0be6a90>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/09/21 17:45:39] (ERROR) freenasOS.Configuration.TryGetNetworkFile():709 - Unable to load ['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt']: Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt
[2020/09/21 17:45:39] (WARNING) application.call_method():168 - Exception while calling update.check_available(*[])
    io_thread=False)
    return fut.result()
    raise url_exc
[2020/09/21 17:45:39] (DEBUG) application.__crash_reporting():173 - [Crash Reporting] is disabled using sentinel file.
[2020/09/21 17:59:05] (DEBUG) EtcService.generate():275 - No new changes for /etc/krb5.conf
I also took a debug after trying to connect using the settings above, I've attached the ActiveDirectory one in the next post. It seems to be checking the workgroup for a trust secret (still) instead of the domain.
andrewjones216
ActiveDirectory debug:
+                      Active Directory Status @1600707853                       +
Active Directory is DISABLED
debug finished in 0 seconds for Active Directory Status
+                    Active Directory Run Status @1600707853                     +
nmbd is running as pid 23133.
smbd is running as pid 23114.
winbindd is running as pid 23125.
+                                   @1600707853                                  +
+                         SMB Service Status @1600707853                         +
SMB will start on boot.
debug finished in 0 seconds for SMB Service Status
+                     Active Directory Settings @1600707853                      +
  "id": 1,
  "domainname": "OUR.DOMAIN",
  "bindname": "username",
  "ssl": "OFF",
  "certificate": null,
  "validate_certificates": true,
  "verbose_logging": true,
  "allow_trusted_doms": false,
  "use_default_domain": true,
  "allow_dns_updates": false,
  "disable_freenas_cache": false,
  "site": "",
  "kerberos_realm": null,
  "kerberos_principal": "",
  "createcomputer": "",
  "timeout": 5000,
  "dns_timeout": 5000,
  "idmap_backend": "RID",
  "nss_info": null,
  "ldap_sasl_wrapping": "SIGN",
  "enable": false,
  "netbiosname": "CNAS05",
  "netbiosalias": []
debug finished in 0 seconds for Active Directory Settings
+                           /etc/krb5.conf @1600707853                           +
debug finished in 0 seconds for /etc/krb5.conf
+                         /etc/nsswitch.conf @1600707853                         +
group: files
hosts: files dns
networks: files
passwd: files
shells: files
services: files
protocols: files
rpc: files
sudoers: files
debug finished in 0 seconds for /etc/nsswitch.conf
+                      /usr/local/etc/smb4.conf @1600707853                      +
[global]
        dns proxy = No
        aio max threads = 2
        load printers = No
        printing = bsd
        dos filemode = Yes
        log level = 3
        logging = file
        netbios aliases =
        workgroup = our.workgroup
debug finished in 0 seconds for /usr/local/etc/smb4.conf
+                     Kerberos Tickets - 'klist' @1600707853                     +
klist: No ticket file: /tmp/krb5cc_0
debug finished in 0 seconds for Kerberos Tickets - 'klist'
+                   Kerberos Principals - 'ktutil' @1600707853                   +
ktutil: krb5_kt_start_seq_get FILE:/etc/krb5.keytab: keytab /etc/krb5.keytab open failed: No such file or directory
debug finished in 0 seconds for Kerberos Principals - 'ktutil'
+            Active Directory Trust Secret - 'wbinfo -t' @1600707853             +
wbcCheckTrustCredentials(our.workgroup): error code was NT_STATUS_NO_SUCH_DOMAIN (0xc00000df)
checking the trust secret for domain our.workgroup via RPC calls failed
debug finished in 0 seconds for Active Directory Trust Secret - 'wbinfo -t'
+         Active Directory NETLOGON connection - 'wbinfo -P' @1600707853         +
failed to call wbcPingDc: WBC_ERR_DOMAIN_NOT_FOUND
checking the NETLOGON for domain[our.workgroup] dc connection to "" failed
debug finished in 0 seconds for Active Directory NETLOGON connection - 'wbinfo -P'
+           Active Directory trusted domains - 'wbinfo -m' @1600707853           +
Domain Name     DNS Domain                                                       Trust Type  Transitive  In   Out
BUILTIN        Local
CNAS05        Local
debug finished in 0 seconds for Active Directory trusted domains - 'wbinfo -m'
+       Active Directory all domains - 'wbinfo --all-domains' @1600707853        +
BUILTIN
CNAS05
debug finished in 0 seconds for Active Directory all domains - 'wbinfo --all-domains'
+        Active Directory own domain - 'wbinfo --own-domain' @1600707853         +
our.workgroup
debug finished in 0 seconds for Active Directory own domain - 'wbinfo --own-domain'
+     Active Directory online status - 'wbinfo --online-status' @1600707853      +
BUILTIN : active connection
CNAS05 : active connection
debug finished in 1 seconds for Active Directory online status - 'wbinfo --online-status'
+     Active Directory domain info - 'wbinfo --domain-info=our.workgroup' @1600707854      +
failed to call wbcDomainInfo: WBC_ERR_DOMAIN_NOT_FOUND
Could not get domain info
debug finished in 0 seconds for Active Directory domain info - 'wbinfo --domain-info=our.workgroup'
+  Active Directory DC name - 'wbinfo --dsgetdcname="OUR.DOMAIN"' @1600707854  +
Could not find dc for "OUR.DOMAIN"
debug finished in 2 seconds for Active Directory DC name - 'wbinfo --dsgetdcname="OUR.DOMAIN"'
+         Active Directory DC info - 'wbinfo --dc-info=our.workgroup' @1600707856          +
Could not find dc info our.workgroup
debug finished in 0 seconds for Active Directory DC info - 'wbinfo --dc-info=our.workgroup'
+                Active Directory Users - 'wbinfo -u' @1600707856                +
Error looking up domain users
+               Active Directory Groups - 'wbinfo -g' @1600707856                +
failed to call wbcListGroups: WBC_ERR_DOMAIN_NOT_FOUND
Error looking up domain groups
debug finished in 0 seconds for Active Directory Groups - 'wbinfo -g'
+                     Active Directory SPN list @1600707856                      +
[EFAULT] Failed to generate SPN list: [ads_connect: No logon servers are currently available to service the logon request.
ads_connect: No logon servers are currently available to service the logon request.]
    io_thread=False)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1084, in _call
    return await methodobj(*args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py", line 1370, in get_spn_list
    f"Failed to generate SPN list: [{netads.stderr.decode().strip()}]"
middlewared.service_exception.CallError: [EFAULT] Failed to generate SPN list: [ads_connect: No logon servers are currently available to service the logon request.
debug finished in 4 seconds for Active Directory SPN list
andrewjones216
Hi all,
Following on my last posts we have upgraded our NAS to 11.3-U5. When joining the domain once again this happened:
So I pulled the middleware log, which did have some different errors. In particular the error "SASL GSSAPI bind failed" is in there a couple of times. The interface than stopped responding for around 45 mins before letting me log back in:
[2020/11/03 17:51:37] (DEBUG) application.__crash_reporting():173 - [Crash Reporting] is disabled using sentinel file.
[2020/11/03 17:53:22] (DEBUG) EtcService.generate():275 - No new changes for /etc/krb5.conf
[2020/11/03 18:06:18] (DEBUG) ActiveDirectoryService.get_n_working_servers():167 - Request for [1] of server type [PDC] returned: [{'host': 'CWM-DC-02.our.domain', 'port': 389}]
[2020/11/03 18:06:18] (DEBUG) ActiveDirectoryService.start():953 - Starting Active Directory service for [OUR.DOMAIN]
[2020/11/03 18:06:31] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/11/03 18:06:32] (WARNING) UpdateService.get_trains():297 - Failed to retrieve trains redirection
    raise err
    sock.connect(sa)
    chunked=chunked,
    conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x836c56850>: Failed to establish a new connection: [Errno 61] Connection refused
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x836c56850>: Failed to establish a new connection: [Errno 61] Connection refused'))
    timeout=5,
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains_redir.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x836c56850>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/11/03 18:06:32] (DEBUG) freenasOS.Configuration.TryGetNetworkFile():606 - TryGetNetworkFile(['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt'])
[2020/11/03 18:06:32] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update.ixsystems.com:443
[2020/11/03 18:06:32] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x833438950>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/11/03 18:06:32] (DEBUG) urllib3.connectionpool._new_conn():959 - Starting new HTTPS connection (1): update-master.ixsystems.com:443
[2020/11/03 18:06:32] (ERROR) freenasOS.Configuration.TryGetNetworkFile():692 - Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: HTTPSConnectionPool(host='update-master.ixsystems.com', port=443): Max retries exceeded with url: /FreeNAS/trains.txt (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x836ae78d0>: Failed to establish a new connection: [Errno 61] Connection refused'))
[2020/11/03 18:06:32] (ERROR) freenasOS.Configuration.TryGetNetworkFile():709 - Unable to load ['https://update.ixsystems.com/FreeNAS/trains.txt', 'https://update-master.ixsystems.com/FreeNAS/trains.txt']: Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt
[2020/11/03 18:06:32] (WARNING) application.call_method():168 - Exception while calling update.check_available(*[])
    io_thread=False)
    return fut.result()
    raise url_exc
[2020/11/03 18:06:32] (DEBUG) application.__crash_reporting():173 - [Crash Reporting] is disabled using sentinel file.
[2020/11/03 18:07:34] (DEBUG) ActiveDirectoryService.port_is_listening():105 - connection to cdc01.our.domain failed with error: [Errno 60] Operation timed out
[2020/11/03 18:07:34] (DEBUG) ActiveDirectoryService.get_n_working_servers():167 - Request for [3] of server type [DOMAINCONTROLLER] returned: [{'host': 'cwm-dc-02.our.domain', 'port': 389}, {'host': 'CWM-DC-01.our.domain', 'port': 389}, {'host': 'CWM-DC-02.our.domain', 'port': 389}]
[2020/11/03 18:07:34] (DEBUG) ActiveDirectoryService._open():240 - Successfully initialized LDAP server: [ldap://cwm-dc-02.our.domain:389]
[2020/11/03 18:25:03] (DEBUG) ActiveDirectoryService._open():348 - SASL GSSAPI bind failed.
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py", line 341, in _open
    self._handle.sasl_gssapi_bind_s()
  File "/usr/local/lib/python3.7/site-packages/ldap/ldapobject.py", line 487, in sasl_gssapi_bind_s
    self.sasl_non_interactive_bind_s('GSSAPI',serverctrls,clientctrls,sasl_flags,authz_id)
  File "/usr/local/lib/python3.7/site-packages/ldap/ldapobject.py", line 475, in sasl_non_interactive_bind_s
    self.sasl_interactive_bind_s('',auth,serverctrls,clientctrls,sasl_flags)
  File "/usr/local/lib/python3.7/site-packages/ldap/ldapobject.py", line 465, in sasl_interactive_bind_s
    return self._ldap_call(self._l.sasl_interactive_bind_s,who,auth,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls),sasl_flags)
  File "/usr/local/lib/python3.7/site-packages/ldap/ldapobject.py", line 329, in _ldap_call
    reraise(exc_type, exc_value, exc_traceback)
  File "/usr/local/lib/python3.7/site-packages/ldap/compat.py", line 44, in reraise
    raise exc_value
  File "/usr/local/lib/python3.7/site-packages/ldap/ldapobject.py", line 313, in _ldap_call
    result = func(*args,**kwargs)
ldap.LOCAL_ERROR: {'desc': 'Local error', 'errno': 60, 'info': 'SASL(-1): generic failure: GSSAPI Error:  Miscellaneous failure (see text)OUR.DOMAIN (unable to reach any KDC in realm OUR.DOMAIN)'}
[2020/11/03 18:25:03] (WARNING) aiohttp.websocket._send_frame():565 - websocket connection is closing.
[2020/11/03 18:25:03] (DEBUG) ActiveDirectoryService._open():240 - Successfully initialized LDAP server: [ldap://CWM-DC-01.our.domain:389]
[2020/11/03 18:42:32] (DEBUG) ActiveDirectoryService._open():348 - SASL GSSAPI bind failed.
    raise exc_value
[2020/11/03 18:42:32] (WARNING) aiohttp.websocket._send_frame():565 - websocket connection is closing.
[2020/11/03 18:42:32] (DEBUG) ActiveDirectoryService._open():240 - Successfully initialized LDAP server: [ldap://CWM-DC-02.our.domain:389]
[2020/11/03 19:00:01] (DEBUG) ActiveDirectoryService._open():348 - SASL GSSAPI bind failed.
    raise exc_value
[2020/11/03 19:00:01] (WARNING) aiohttp.websocket._send_frame():565 - websocket connection is closing.
[2020/11/03 19:00:01] (WARNING) asyncio.write():863 - socket.send() raised exception.
[2020/11/03 19:00:01] (ERROR) middlewared.job.run():361 - Job <bound method ActiveDirectoryService.start of <middlewared.plugins.activedirectory.ActiveDirectoryService object at 0x80e1d3b50>> failed
    await self.future
  File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 385, in __run_body
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py", line 983, in start
    new_site = await self.middleware.call('activedirectory.get_site')
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1141, in call
    app=app, pipes=pipes, job_on_progress_cb=job_on_progress_cb, io_thread=True,
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py", line 1567, in get_site
    site = AD_LDAP.locate_site()
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py", line 529, in locate_site
    self._open()
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py", line 353, in _open
    self._convert_exception(saved_bind_error)
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py", line 212, in _convert_exception
    raise CallError(f"{errmsg} {type(ex)}")
middlewared.service_exception.CallError: [EFAULT] Local error: SASL(-1): generic failure: GSSAPI Error:  Miscellaneous failure (see text)OUR.DOMAIN (unable to reach any KDC in realm OUR.DOMAIN) <class 'ldap.LOCAL_ERROR'>
[2020/11/03 19:00:01] (WARNING) middlewared.__periodic_task_wrapper():872 - Exception while calling periodic task
Any help debugging this on-going issue for us would be appreciated!
anodos
Sambassador
In 12.0 I rewrote the AD plugin to use samba's python bindings to perform our intial AD lookups of domain info (entirely removed py-ldap from the AD-side of directory services). Perhaps try 12.0-RELEASE in a VM and see if you have better luck there.
andrewjones216
Hi Anodos,
Thanks for the quick reply. We'd spoke about using 12.0-RELEASE here yesterday and could test on a VM. We won't be actually moving to it for production until U1.
We do have one NAS on 11.3-U5 that is connected to AD ok, and has remained that way through a nnumber of upgrades.
Do you think a rebuild of the NAS will make any difference here?
andrewjones216
Hi Anodos,
I finally managed to get a maintainance window to perform a fresh install (11.3-U5) on this box. Happy to say that firstly really impressed with the way FreeNAS handled exporting and importing of our pools (8 of them, totalling 60 disks!). Secondly that the AD join worked for us after completing the install.
I increased the AD and DNS timeouts and used SIGN in the auth method.
Thank you for your help on this, it has been invaluable.
Cheers
A
