I looked around, but couldn't find anyone else reporting this issue.
I just upgraded to FreeNAS 11.2Beta2 and decided to recreate my jails on the new iocage platform. I created the transmission jail using the transmission plugin v2.94.
After it installed and was running, I went to "Manage" from the UI and got this error:
I hadn't assigned the jail any storage, so I thought that might be related... so I shutdown the jail, added storage (or a new Mount Point) and started the jail... same error. I checked the permissions for the added storage and of the jail. So I went to the jail dir and
Restarted the jail... Same error. Anyone have any ideas??
Thank you in advance!
404: Not Found Couldn't find Transmission's web interface files! Users: to tell Transmission where to look, set the TRANSMISSION_WEB_HOME environment variable to the folder where the web interface's index.html is located. Package Builders: to set a custom default at compile time, #define PACKAGE_DATA_DIR in libtransmission/platform.c or tweak tr_getClutchDir () by hand.
chown -R transmission:transmission *
