FreeNAS 11.2-U4.1 & watchdog hard resets => unexpected reboots
getcom
Hello to all,
I need some hints to find the root cause of unexpected system reboots due to watchdog hard resets.
The system is FreeNAS 11.2-U4.1 running on a 3HE Supermicro Superserver Hardware with MB X10DRi, 2x Intel XEON E5-2640 v4, 256GB ECC RAM, LSI SAS 9305-16i, 16x HGST SAS 10TB + 2x Intel SSDSC2KB960G8, 2x Intel Optane P4800X SSDPED1K375GA01, 1x Intel X710 Dual SFP+, 1x Mellanox Dual Infiniband ConnectX-2.
FreeNAS is working as an iSCSI multipath (2 x Infiniband subnet, IPoIB) and a NFS server (over LACP lagg, SFP+) for a Proxmox cluster. The system is running on the Intel SSD mirrow, the HGSTs are used as 8 mirrored VDEVs in a pool. The Optanes are the mirrored SLOG device for the pool.
If a reset/reboot happens the VMs are running into trouble and have to be rebootet.
At the moment there is at least one reset a day.
After a reboot there is absolutely nothing interesting in the FreeNAS system logs.
In the IPMI event logs there are entries like that, which is all what I have at the moment:
2019/05/27 23:58:13 #0xca Watchdog 2 Timer Interrupt - Assertion
2019/05/27 23:58:14 #0xca Watchdog 2 Hard Reset - Assertion
2019/05/29 17:53:58 #0xca Watchdog 2 Timer Interrupt - Assertion
2019/05/29 17:53:59 #0xca Watchdog 2 Hard Reset - Assertion
2019/05/31 22:12:05 #0xca Watchdog 2 Timer Interrupt - Assertion
2019/05/31 22:12:06 #0xcaWatchdog 2 Hard Reset - Assertion
2019/05/31 22:40:02 #0xca Watchdog 2 Timer Interrupt - Assertion
2019/05/31 22:40:03 #0xca Watchdog 2 Hard Reset - Assertion
Watchdog is disabled in BIOS.
I created an entry in System / Tuneables: "watchdogd_enable" with a value "NO" and type rc.conf. A "/etc/rc.d/watchdogd onestatus" tells me it is not running, "ipmitool sdr" tells me all is ok., "ipmitool chassis status" says all is fine.
# ipmitool mc watchdog get
Watchdog Timer Use: SMS/OS (0x04)
Watchdog Timer Is: Stopped
Watchdog Timer Actions: Hard Reset (0x01)
Pre-timeout interval: 0 seconds
Timer Expiration Flags: 0x10
Initial Countdown: 274 sec
Present Countdown: 0 sec
The server parts are new, except the Mellanox card, the hardware is working and tested, all is fine but nevertheless the system is resetting and I have no clue where it comes from. There is still a kernel module ipmi.ko loaded.
I assume that I have either a system incompatibility with FreeBSD/FreeNAS, maybe with the Mellanox driver, a hardware fault (but where if all is green?) or a bug somewhere in the IPMI FreeBSD stuff or something completely unknown.
The question for me is: what is triggering the reset and how could I find it?
Does anybody has an idea how to get that encirceled? Disable the IPMI kernel module and check if the server will freeze?
Thank you in advance.
Ralf
D
dlavigne
Guest
Go ahead and create a report at bugs.ixsystems.com and post the issue number here.
