SOLVED freenas 11.2 b3 iso on a pendrive make win 7 bsod
yomismo
step to reproduce if anyone is interested
1 get etcher https://etcher.io/
2 download freenas 11.2 b3
3 get USB pendrive
4 flash freenas iso on said pen
5 disconnect and connect said pen to a usb => win7 instant bsod
i tested other usb ports and pendrive
kdragon75
Try using Rufus instead of etcher.
kdragon75
RiBeneke
Attempting to upgrade our FreeNAS 9.10.2-U6 to the latest 11.2-U5 or 11.2-U6.
I have been having the same problem.
FreeNAS 11.2 iso has something in it that creates a corrupt partition table when written to a usb stick using Rufus or other writer on win 7 x64 pro pc.
The corrupted usb stick will then instantly crash (BSD) a Windows system
when plugged into Win7 x64 Pro, Win7 x32 Starter or Win 10 (all have the latest Windows updates).
See this discussion of the problem :
https://github.com/pbatard/rufus/issues/1188
I am experimenting further to find a workaround.
RiBeneke
The Microsoft tool for writing an iso file to a usb stick
downloaded 2019-09-25 as <Windows7-USB-DVD-Download-Tool-Installer-en-GB.exe>
reports that FreeNAS-11.2-U5.iso and FreeNAS-11.2-U6.iso (also downloaded in the last few days) are invalid iso files
so there is some incompatibility with Windows 7 Professional (x64) Service Pack 1 (build 7601).
RiBeneke
Testing made several bricked USB memory sticks using Windows 7 pc.
Bought some more.
Used the same downloaded FreeNAS .iso files and Rufus on a Windows 10 pc.
Creating the USB boot device worked perfectly as per documentation.
It seems to be a problem inside some versions / builds of Windows 7, strangely only happened with FreeNAS .iso files.
sys-d
I'm trying to setup my first FreeNAS and I'm having the same problem with Windows 7 and Windows 10 blue screening just after completing the write of FreeNAS-11.2-U6.iso to a USB stick by Rufus. Whatever is in that iso is lethal -- very consistently blue screens Windows. I've tried 3 sticks by 2 different manufacturers. All same result.
I use Rufus on a regular basis to create bootable USB sticks for other iso's (clonezilla, etc.) and never had any such issues.
I used windbg.exe on Windows 7 to extract info from a .dmp file produced by one of the blue screens.
It shows an Integer division by zero exception in Windows Partition Management Driver.
11: kd> !analyze -v
*                        Bugcheck Analysis                                    *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000094, The exception code that was not handled
Arg2: fffff8801c7a8e60, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 0000000000000000, Parameter 1 of the exception
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000094 - {EXCEPTION}  Integer division by zero.
11: kd> lmvm partmgr
start             end                 module name
fffff880`00e66000 fffff880`00e7b000   partmgr    (pdb symbols)          c:\symcache\partmgr.pdb\7E391DC4AAAC45C4A8D0FA49903564362\partmgr.pdb
    Loaded symbol image file: partmgr.sys
    Mapped memory image file: c:\symcache\partmgr.sys\4F641BC115000\partmgr.sys
    Image path: \SystemRoot\System32\drivers\partmgr.sys
    Image name: partmgr.sys
    Timestamp:        Sat Mar 17 00:06:09 2012 (4F641BC1)
    CheckSum:         0001DFC8
    ImageSize:        00015000
    File version:     6.1.7601.17796
    Product version:  6.1.7601.17796
    File flags:       0 (Mask 3F)
    File OS:          40004 NT Win32
    File type:        3.7 Driver
    File date:        00000000.00000000
    Translations:     0000.04b0
    CompanyName:      Microsoft Corporation
    ProductName:      Microsoft® Windows® Operating System
    InternalName:     partmgr.sys
    OriginalFilename: partmgr.sys
    ProductVersion:   6.1.7601.17796
    FileVersion:      6.1.7601.17796 (win7sp1_gdr.120316-1742)
    FileDescription:  Partition Management Driver
    LegalCopyright:   © Microsoft Corporation. All rights reserved.
Dump analysis is attached.
While the driver should *not* bsod under any circumstance (technically it's a Microsoft driver unhandled exception), however it would to great if this could be fixed by releasing a FreeNAS iso that doesn't do this. Also, it'd be good to warn on the FreeNAS downloads page that this iso may cause Windows 7 and Windows 10 system to blue screen when creating a USB stick. It's really unnerving.
I've been able to burn a CD this the iso image without issue.
  • dump-dbg.txt
