learnsomemore
- Aug 16, 2018
I created a script and it works from the terminal but when trying it in GUI via "Run Now", it get error permission denied. I did the following setup:
FreeNAS 11.1-U6
Directory uses windows permissions
Error when running script from FreeNAS GUI:
if i change <USER> to root, i no longer get permission denied but the script fails because it's not being run as the correct user with ssh key.
Does <USER> need some other special permission for this to work from FreeNAS GUI?
- Created bash script
- ssh into FreeNAS as root and then su <USER>.
- Ran script with ./scriptname
- See the script ran successfully (script does a rsync and outputs success and error msg to a file)
- Next I went to FreeNAS GUI > Tasks > Cron Jobs
- User: = <USER>
- Command: absolute path to script (/mnt/vol1/<directory>/<filename>)
- Redirect Stdout and Stderr are not checked
FreeNAS 11.1-U6
freenas cronjob: /bin/sh: /mnt/vol1/Directory1/User1/rsync_cron_script: Permission denied
