FreeNAS 11.1 - iocage - pkg missing?
JoeB
I have FN11.1-PRE installed, when i create and enter an iocage jail, pkg appears to be missing and cant be found.
Any ideas?
# pkg update
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/N]: y
Bootstrapping pkg from pkg+http://pkg.FreeBSD.org/FreeBSD:11:amd64/quarterly, please wait...
pkg: Error fetching http://pkg.FreeBSD.org/FreeBSD:11:amd64/quarterly/Latest/pkg.txz: Non-recoverable resolver failure
A pre-built version of pkg could not be found for your system.
Consider changing PACKAGESITE or installing it from ports: 'ports-mgmt/pkg'.
JoeB
I cant ping anything:
# ping pkg.FreeBSD.org
ping: ssend socket: Operation not permitted
The same ping succeeds from the 'old' warden jails.
D
dlavigne
Guest
Does adding an entry of 8.8.8.8 to the iocage jail's /etc/resolv.conf resolve the issue?
JoeB
It's already there:
# Generated by resolvconf
search local
nameserver 8.8.8.8
nameserver 8.8.4.4
nameserver 192.168.1.1
For your iocage jails, make sure you have the flag allow_raw_sockets checked and restart your jail.
You can find this under "Jail Properties' in the new UI.
JoeB
Ive just installed FreeNAS 11.1-RELEASE.
Deleted the jail, and recreated, ticked allow_raw_sockets.
I still cannot ping anything or install pkg.
JoeB
Welcome to FreeBSD!
Release Notes, Errata: https://www.FreeBSD.org/releases/
Security Advisories: https://www.FreeBSD.org/security/
FreeBSD Handbook: https://www.FreeBSD.org/handbook/
FreeBSD FAQ: https://www.FreeBSD.org/faq/
Questions List: https://lists.FreeBSD.org/mailman/listinfo/freebsd-questions/
FreeBSD Forums: https://forums.FreeBSD.org/
Documents installed with the system are in the /usr/local/share/doc/freebsd/
directory, or can be installed later with: pkg install en-freebsd-doc
For other languages, replace "en" with a language code like de or fr.
Show the version of FreeBSD installed: freebsd-version ; uname -a
Please include that output and any error messages when posting questions.
Introduction to manual pages: man man
FreeBSD directory layout: man hier
Edit /etc/motd to change this login announcement.
root@radarr2:~ # ifconfig
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether 9c:b6:54:0c:a8:23
hwaddr 9c:b6:54:0c:a8:23
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
groups: lo
ether 02:05:b0:13:c7:00
groups: bridge
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 2000
member: epair5a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
member: epair4a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:95:90:00:05:0a
hwaddr 02:95:90:00:05:0a
status: active
groups: epair
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:95:90:00:06:0a
hwaddr 02:95:90:00:06:0a
status: active
groups: epair
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:95:90:00:07:0a
hwaddr 02:95:90:00:07:0a
status: active
groups: epair
epair4a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:95:90:00:08:0a
hwaddr 02:95:90:00:08:0a
status: active
groups: epair
epair5a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:95:90:00:09:0a
hwaddr 02:95:90:00:09:0a
status: active
groups: epair
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:95:90:00:04:0a
hwaddr 02:95:90:00:04:0a
status: active
groups: epair
root@radarr2:~ #
RegularJoe
OK Joe I see your new, are you using iocage commands to get to the console? Have you read the jail part of the manual? I am just starting with iocage jails as well.
iocage list
iocage df
iocage console examplejail
JoeB
Yeah. This was from within the jail. The only way to enter a new gui jail is via iocage AFAIK.
JoeB
I've tried over and over to create a 11.1 jail with access to the internet, but i cannot figure out what else i'm supposed to do!
I've created a fresh 11.1 jail, given it an ipaddress 192.168.1.114.
I cannot ping the jail from windows, and i cannot ping anything from within the jail either.
Can someone please try to create a jail that has internet access with the new GUI and 11.1-RELEASE in the jail, so i can rule out FN not working correctly, please?
D
dlavigne
Guest
Is the subnet mask correct? Is the default gateway and DNS set?
nojohnny101
@dlavigne I am facing the same thing with a newly created iocage jail from within the new GUI. My subnet mask is custom and I can't find anywhere in the GUI to set the subnet mask (I tried adding a /16 to the end of the static IP for the jail but that didn't work either).
This must be set through the CLI? I've been over the documentation multiple times but I could just be missing it.
INCSlayer
this depends on if your using VNET or not but basically if your doing it through the ui then on the line for "ipv4 address" simply write:
if not using vnet:
[name of host interface]|[ip address] example: igb1|192.168.1.16
if using vnet then make sure vnet is checkmarked and do:
vnet0|[ip address]
not entirely sure if its needed or not but i define it for both the jails anyway and that is to set "Default Router" to whatever your standard gateway is.
it is what i have for my test jails and they both have internet
Alecmascot
I had a go through the new gui on 11.1 recently and gave up......
The cli works fine :
iocage create -n examplejail ip4_addr="bge0|192.168.1.10/24" -r 11.1-RELEASE
nojohnny101
I'm still stuck guys. I have tried the manual command that @Alecmascot pointed out but if I use the igb0 interface that my FreeNAS uses then I can no longer SSH into my box (like that creates a conflict).
What "interface" should we choose? If I make one up like "igb1" then the jail won't start because it says the "interface doesn't exist".
nojohnny101
Well I got it working by just going through the interfaces. To be more explicit and to help others. Once inside the jail (by leaving the GUI IPv4 address space with only the IP address and the subnet mask, in my case: 10.0.1.88/16)
- then I would SSH into FN, then into the jail "iocage console jailname"
- type "ifconfig". this will list the available interfaces
- then, in my case, I saw "bridge0" listed
- go back to the GUI, stop the jail, then I added "bridge0|" to the beginning of the IPv4 address in the GUI so it looked like this: bridge0|10.0.1.88/16
then my jail was able to reach the internet
