Inabon
- Dec 22, 2017
After heavy hard drive usage moving big files or leaving it for 8+ hours on GUI and SSh become unresponsive. Jails Work. Plex, transmission, nextcloud function properly.
Dec 22 22:19:30 freenas daemon3073: ==> Newer Consul version available: 1.0.2 (currently running: 1.0.0) <--- i think this may be an issue
have a bunch of these
2017/12/22 22:19:19 [WARN] agent: check "service:nas-health" has the 'script' field, which has been deprecated and replaced with the 'args' field. See https://www.consul.io/docs/agent/checks.html
don´t know how to fix
I was able to replicate issue with errors in consul similar to these
(da1:umass-sim1:1:0:0): WRITE. CDB: 2a 00 00 34 67 4d 00 00 80 00
(da1:umass-sim1:1:0:0): CAM status: CCB request completed with an error
(da1:umass-sim1:1:0:0): Retrying command
(da1:umass-sim1:1:0:0): Error 5, Retries exhausted
It happens only when moving big files for example transmission moves a download from dir incomplete to Downloads dir
forgot to mention jails continue to work pretty normally even though ui and ssh quit responding.
ssh on jails works fine if you are logged in to jail through jexec but when you exit jail ssh to main system is frozen
hardware I had to reboot this morning.
Build FreeNAS-11.1-RELEASE
Platform Intel(R) Xeon(R) CPU L5420 @ 2.50GHz
Memory 24537MB <---ECC
System Time Sat, 23 Dec 2017 06:21:17 -0500
Uptime 6:21AM up 4 mins, 0 users
Load Average 0.48, 0.36, 0.16
