Is it possible that the new version is causing ATA errors? Specifically I started getting the following errors after the update. At first I thought that it was the drives failing (and they probably were) so I started replacing them. However after burn in and testing (and passing) the new drives are now showing the same error message (see below, this drive is only 165 hours old and already has 2 errors). Just wondering if it is bad luck, in which case I have a lot of it with drives, or if the new version is sending some command that could be causing this. I have no idea if that is even possible, but I wanted the communities feed back, and was wondering if I was alone with this error.
ATA Error Count: 2 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 2 occurred at disk power-on lifetime: 165 hours (6 days + 21 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 10 51 08 70 02 40 40 Error: IDNF at LBA = 0x00400270 = 4194928 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 08 70 02 40 40 08 4d+07:20:44.476 WRITE DMA Error 1 occurred at disk power-on lifetime: 85 hours (3 days + 13 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 10 51 08 f8 01 40 40 Error: IDNF at LBA = 0x004001f8 = 4194808 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 08 f8 01 40 40 08 22:35:08.291 WRITE DMA Test_Description Status Remaining LifeTime(hours) LBA_of_first_error Extended offline Completed without error 00% 10 -
