Hi folks,
Do I understand something correctly - if you plan on installing FreeNAS and, effectively, making a bunch of disks into a DIY SAN, you should NOT use a hardware RAID card?...all you need to basically do is get the host machine to SEE all of the drives (which is why cheap SAS cards are so handy), and ZFS will handle the RAID functionality...is that right?
Also, does it matter if all of the disks are the same size? What happens if they're NOT all the same size?
Thank you!
Ed
Thank you!
Ed
