free nas can't create pool
oileri
When I try to create a pool on freenas I get the following error I have RAID5 configuration on the computer I say create a pool on freenas and such an error occurs
Thanks
oileri
won't work with hardware raid and which one do you think would be healthier
oileri
So how can I implement the raid 5 structure, I use 3 discs in freenas environment so that 1 will continue when it breaks down
blueether
dont use a raid controler... then setup the disks with software raid (Raidz1 in your example)
Read Uncle Fester's FreeNAS Beginner's Guide and the manual for starters
and I have to ask why you are using the old GUI
