Norbert Irmer
- Jan 27, 2020
I have the problem, that after booting FreeNas, I see 4 smartctl processes running with 100% wcpu, eg.:
smartctl -i -d areca,14 /dev/arcmsr0
This is wrong, I have an areca 1882x raid adapter, this is a SAS controller, not SATA. A correct command line is
for example:
smartctl -i -d areca 1/2 /dev/arcmsr0 (slot #1, encasement #2)
If I kill the running smartctl processes with wrong parameters, and enter the above command line,
I get the SMART infos, otherwise the command hangs.
I am using an areca 1882xx raid adapter with latest bios V1.56 2019-07-30 in JBOD mode. Passthrough mode seems to
be Ok now with areca cards and latest bios, only the smartctl command is wrong.
I need help, how can I set the correct device settings for smartctl ?
Thanks,
Norbert
for example:
Thanks,
Norbert
