Wolfeman0101
- Jun 14, 2012
Thanks for the help so far @Pentaflake !
It seems I've run into another snag. I just couldn't get the sonarr install to work. I kept getting errors. Now I know it's not supposed to work like this, but I decided to reboot my FreeNAS and try again.
Aaaand now none of the iocage-built instances have network access outside their jails. The SABNZBD jail works fine but the Plex, PlexPy and Organizr ones I've set up cannot.
Looking at the result ofiocage get all plexpass, everything seems to be as it should (I think):
Code:defaultrouter:192.168.1.1 host_hostname:plexpass interfaces:vnet0:bridge0 ip4:new ip4_addr:vnet0|192.168.1.120/24 ip4_saddrsel:1
In each cage the /etc/resolv.conf looks fine, with the DNS servers showing up (oddly, the gateway is last on the list, but putting it at the top didn't resolve anything).
But still, the instances can't see outside the network, with any ping showing
Code:root@plexpass:~ # ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes ping: sendto: No route to host ping: sendto: No route to host ping: sendto: No route to host
Traceroute showsas well.Code:no route to host
Is there something I need to do to kickstart the networking for the iocage instances?
Seems like there are some bugs with iocage. Adding these lines to the tuneables fixed it for me.Thanks for the help so far @Pentaflake !
https://forums.freenas.org/index.php?threads/iocage-vnet0-and-bridge0.59964/
