omid_1985
- Aug 22, 2018
If you have webfinger and nodeinfo warning after upgrading your TrueNAS Nextcloud plugin to version 21 or 22, here is the fix:
Inside your Nextcloud jail:
Add webfinger and nodeinfo locations into /usr/local/etc/nginx/conf.d/nextcloud.conf :
Restart your jail and test with a cleaned cache browser.
Source.
location ^~ /.well-known { # The following 6 rules are borrowed from `.htaccess` rewrite ^/\.well-known/host-meta\.json /public.php?service=host-meta-json last; rewrite ^/\.well-known/host-meta /public.php?service=host-meta last; rewrite ^/\.well-known/webfinger /public.php?service=webfinger last; rewrite ^/\.well-known/nodeinfo /public.php?service=nodeinfo last; location = /.well-known/carddav { return 301 /remote.php/dav/; } location = /.well-known/caldav { return 301 /remote.php/dav/; } location = /.well-known/webfinger { return 301 //index.php/.well-known/webfinger; } location = /.well-known/nodeinfo { return 301 //index.php/.well-known/nodeinfo; } try_files $uri $uri/ =404; }
Source.
