FIXED: Docker UI options not visible/saving
flatline69
I googled this and came across this Jira entry:
So I downloaded the latest release from here:
And now running TrueNAS-SCALE-21.06-MASTER-20210618-092920 from TrueNAS-SCALE-21.04-ALPHA.1
Based on the Jira entry, this should be fixed? Or am I not on the right train (ticket mentioned 21.06-BETA.1)
I've deployed a container from the UI (this time, I didn't circumvent anything around Docker as I did in a previous post) and it deploys but when I go to edit the settings of the container, they're not there. I've tried adding environment variables, volumes, etc but it never shows in the UI. I also added port redirections which shows on the tile in the UI but not in the editor UI.
This is sort of why I had originally circumvented the UI for docker, etc. I realize it's a WIP but I can't tell where my settings are or what they are. Is there a way to view/change this from CLI (not the middleware tool but actual cli, ie: ssh)
flatline69
I think the correct Bug ID is:
SCALE 21.06 BETA comes out next week, but it should be fixed in latest nightly? Can you check next week or provide some diagnostics to this bug.
What sort of diagnostics are need? I'm more than happy to work through the issue. I see the "Debug" button and I assume file a bug? There a link where I can read what to provide (to help everyone involved.)
edit: filed bug: https://jira.ixsystems.com/browse/NAS-111101
flatline69
Fixed in TrueNAS-SCALE-21.06-MASTER-20210618-172919
