Nvious1
- Jul 12, 2018
Hi all, first time FreeNASer here and looking to retire an old 4-bay ReadyNAS and build my own for the obvious reasons that I don't need to restate to you all. I am looking for hardware recommendations or maybe references to past builds that could fit my needs as I need to get something up and running probably within a month before this old nas kicks the bucket. In the new build, I am looking for the following requirements, which would be a combination of things that I am using the old nas and a windows machine for today:
I need about 16 TB usable of storage for backups, media, etc.
I am unsure if I should go with 6TB or 8TB drives but I know I want to run RaidZ2. Should I mix in some SSD as well?
I am ok with used hardware if its still got some decent life on it except the drives. I will buy those new.
I would like to run Plex (max of 4 transcoding 1080p streams) most of my clients play direct or I have optimized versions as needed
I would like to run VMs (at least 1 or 2 running full time either windows or linux but light specs) so thinking I should shoot for 64 GB Ram
Case Form Factor: I have no restrictions, here except don't want cooling issues. Its going to run down in the basement so noise isn't really an issue, although building it quiet doesn't hurt. Could be rack mount or desktop or nas case.
Budget: $2500
I originally was looking at following the DIY 2017 Nas build from Brian Moses and trying to look at all the recent build threads. There are just so many options I am really looking for some help.
Budget: $2500
