blahhumbug
- Apr 25, 2015
I'm brand new to the FreeNAS community and NASes in general. I've been planning to build one for years, but was just never happy with the part combinations I could find, the price points, and the total noise levels and power consumption levels of the parts I would try to combine. This year, I finally came up with a part list that makes me really excited to build my first NAS, so I just pulled the trigger and ordered everything.
Asrock C2750D4I (Avoton 8-core)
4 x Kingston 8GB DDR3-1600 ECC Unbuffered (KVR16E11K4/32)
8 x Western Digital Red 3TB (WD30EFRX) - raid-z2
Silverstone DS380B Mini ITX Tower Case
Silverstone Strider Gold 450W SFX Power Supply (ST45SF-G)
Sandisk Cruzer Fit 32GB USB 2.0 Flash Drive (for FreeNAS)
Cyberpower CP850PFCLCD UPS (850VA/510W)
I recognize that some of the parts are a little overkill for the components, particularly the PSU (450 watt) and the UPS (510 watt). I estimate that the system idle power will be around 75w and 120w at full load. However, I have a secondary goal of having the quietest system I possibly can. It will be sitting only 4 feet away from my main workstation which is also very silent, so I'm trying to avoid adding more noise to the room as much as possible. The case requires an SFX power supply, so that also removed a lot of lower power options. I don't mind the UPS being oversized though as that just increases my uptime during a powerloss to somewhere around 20-30 minutes and also gives me room to plug the wifi/switch and cable-modem into it as well.
I chose the 8-core Avoton instead of the 4-core because I plan to run a plexserver and a few other services on the machine. I also wanted to leave a little bit of headroom for future growth and additional services. I'd like this NAS build to last me at least 5 years.
I really wanted to pick up 2 x 16GB of ECC unbuffered memory so that I had room to add 2 more dimms for 64B total in the future. However, I couldn't find anyone selling that size with unbuffered ecc. I saw a lot of forum posts here with people using this combination of Kingston memory, so I decided to just stick with that. I think 32GB of mem should be fine in this machine for the next 5 years as I do not have plans to do deduplication.
I made the decision to go with WD Red drives over the Red Pro drives due to both cost and and noise. The Pros were significantly louder during seek in WDs published specs (34dba vs 24dba). I chose the Red drives over other similar 3TB options mostly because of their idle power consumption (~5w) and noise levels.
I chose to fill out all 8 hotplug slots of the case with 3TB drives rather than going with a smaller number of 6TB drives. I decided I liked the idea of being able to slowly upgrade 3TB drives to 6TB drives if/as they fail. And if at anypoint I start getting too full, I can pull the trigger and upgrade them all to 6TB and grow the pool. Additionally, the pricing point of 8x3TB vs 4x6TB was better.
I hope to get the parts this week, and will update this post with some photos of the system and benchmark numbers once I've got it up and running.
Cheers!
Cheers!
