All tests are done with 64gb of data.
RaidZ3
[root@AndyNas ~]# dd count=65536 bs=1m if=/dev/zero of=/mnt/tank/abc.txt 65536+0 records in 65536+0 records out 68719476736 bytes transferred in 29.608799 secs (2320914022 bytes/sec)
= 2,16GB/s
[root@AndyNas ~]# dd count=65536 bs=1m if=/dev/urandom of=/mnt/tank/abc.txt 65536+0 records in 65536+0 records out 68719476736 bytes transferred in 766.885670 secs (89608503 bytes/sec)
= 85,46MB/s
RaidZ2
[root@AndyNas ~]# dd count=65536 bs=1m if=/dev/zero of=/mnt/tank/abc.txt 65536+0 records in 65536+0 records out 68719476736 bytes transferred in 24.837061 secs (2766811940 bytes/sec)
= 2,58GB/s
[root@AndyNas ~]# dd count=65536 bs=1m if=/dev/urandom of=/mnt/tank/abc.txt 65536+0 records in 65536+0 records out 68719476736 bytes transferred in 751.110488 secs (91490504 bytes/sec)
= 87,25MB/s
I know this is not the best test, but its good enought for mee.
2MB/s more is not enought for me to switch to RaidZ2, i will stay with RaidZ3.
Now i just need to get the cooling of my hdds better, right now they get up to 38°C
and thats too much, i want them belowe 35°C. i think another fan blowing on them
will do the job. im at 70W idle without any standby/spin down stuff.
I'm playing around with power mode S3 right now, combined with wake on lan.
It seems to work well, the system gets down to 5W like that. If i can make sure it will
always work, im going to use that.
Once again i want to thank all here for the great help!
edit:
Over a samba share i get 115 mb/s write and read, so my gbit network is maxed out anyway. Unless i upgrade to 10gbit network any time soon (will not happen) i will stay with RaidZ3.
